Broke my stuff!! What do I do!! Help me!!!
4/24/2015 3:51 PM
My fork is bent from the inside going out,my headset is on wrong and since te fork is bent I can't pull it out or the fork itself!!!! Also my star nut is completely destroyed and I can't screw it out because the inside is missing!!how do I take it out now!!! I'm Desperate,help me!!!
4/24/2015 3:55 PM
Sawz-All
4/24/2015 3:58 PM
bend it the other way??
4/24/2015 3:59 PM
this what happened!
4/24/2015 5:33 PM
I suggest panhandling
If you can't play music
Ride a unicycle while juggling flaming knives dressed up as a clown
Youl make a killing in no time
4/24/2015 6:38 PM
need a new bike
4/25/2015 8:35 AM
How does that even happen?!
It looks like you over torqued a pinched stem.
Saw the top of the fork off, beat it through the head tube, buy new fork, stem and headset.
Oh, and just to preempt your next question: Odyssey R-series.
4/25/2015 9:09 AM
Saw the top of the fork off, beat it through the ...more
^this ....and it also looks like you kept trying to toghten the compression bolt too. Wow,
4/25/2015 9:32 AM
What brand bike is this?
4/26/2015 5:23 PM
Youl ...more
Yeah sure
4/26/2015 5:24 PM
Dans Comp~the best bmx site smile
4/26/2015 5:25 PM
Do I really have to!?
4/26/2015 5:26 PM
It's by "Stolen Bike Co." I have a stolen sinner 2012 model
4/27/2015 7:46 AM
Your fork is pinched, it is shot. You will likely have to cut it off.
Your headset MIGHT be ok, BUT if you cranked on it too hard, there might be damage.
That star nut is toast. But when you buy a new fork, you won't need it, new forks would either be threaded, or have a welded in "star nut" that would be a lot sturdier.
4/27/2015 6:46 PM
Your headset MIGHT be ok, BUT if you cranked on it too ...more
Forks are pretty expensive alone,do you think I'm better off just buying a new bike,cheap ones like kink and stuff? Cuz my bike is getting pretty bad,and yeah..
4/27/2015 6:56 PM
Just get a new bike
4/28/2015 10:03 AM
Forks are pretty expensive alone,do you think I'm better off just buying a new bike,cheap ones like kink and stuff? Cuz my ...more
Kink isn't cheap angry But, they do make the best bikes for the price, in real life. I know a few people who started on other full chromo bikes from Fit,Cult,Verde,Stolen etc. and they all literally just got destroyed in weeks, i myself started on a 2012 Kink Whip and i had an issue with a hub that kink worked with me twice and replaced the whole wheel in the end, otherwise the parts are mostly still floating around being used by others, since i have upgraded since then.
Buy a full cromoly bike with all sealed everything.
http://www.danscomp.com/products-BIKES/102581/2016_Kink_Whip_Hamlin_Bike_(Tony_Hamlin).html
http://www.danscomp.com/products-BIKES/102580/2016_Kink_Whip_Bike.html
http://www.danscomp.com/products-BIKES/102582/2016_Kink_Liberty_Bike.html
http://www.danscomp.com/products-BIKES/102583/2016_Kink_Liberty_Sexton_Bike.html
http://www.danscomp.com/products-BIKES/102584/2016_Kink_Barrier_Bike.html
http://www.danscomp.com/products-BIKES/102439/2015_Kink_Search_Bike.html
http://www.danscomp.com/products-BIKES/102585/2016_Kink_SXTN_Pro_Bike.html
http://www.danscomp.com/products-BIKES/102566/2015_Haro_SDV2_Bike_(Dennis_Enarson).html
http://www.danscomp.com/products-BIKES/102512/2015_Sunday_Broadcaster_Bike.html
http://www.danscomp.com/products-BIKES/102509/2015_Sunday_Elstran_EX_Bike.html
"It's like riding someone's bike and they got the same frame" -Four
Refs:Four x4,tomdon x5,Xxohioanxx,BigCurn, Don't remember the rest
4/28/2015 10:19 AM
^this.
what on earth were you doing to that poor bike. My guess is you tried to tighten your stem to fix a loose headset, and when that didn't work you tried to tighten your compression bolt without loosening the stem you just tightened. And then you decided to tighten everything again until it broke.
If a bolt still turns under extreeme force, it doesn't mean it's loose. To tighten a fork/compression bolt you need to loosen the stem, then you need to tighten your stem to keep your fork/compression bolt from loosening and causing a loose headset.
Also, your bike is beyond the point of "getting pretty bad" I'm pretty sure that falls under the broken category.
Forks are around $120 a headset is around $20 a cheap bike is twice that ammount.
If you get a new bike and need to fix it, it might be cheaper for you to take it to a shop and have them do it.
4/28/2015 10:57 AM
If your wheels and frame are good, I would invest in the fork, or borrow one from a buddy and then save for replacement parts as you break them. And for God's sake quit hulking the crap out of your bolts hahaahaa
4/29/2015 7:33 AM
It's hammer time man. Start whacking that shit.
I haven't rode in forever so I suck and I have 2 Hondas. Follow me on Instagram @softtop2k.417
