Can I ride my without a washer till I get one?
6/22/2017 9:35 AM
6/22/2017 10:21 AM
Where on your bike is it missing from?
6/22/2017 11:04 AM
It goes directly onto the sprocket
6/22/2017 11:05 AM
This one is not the correct size
6/22/2017 11:21 AM
Does it look like this?
6/22/2017 12:02 PM
Shredkink9 wrote: Photo
If it is this, you might be fine for a little bit. Granted, your sprocket will move around and mess stuff up. So get one as soon as possible.
6/22/2017 12:02 PM
FYI it's called a hat washer
6/22/2017 1:21 PM
I would avoid riding without to avoid damaging your sprocket (which WILL happen)
6/22/2017 3:26 PM
100%
Tried to explain that to my son and he destroyed his sprocket in a week
6/22/2017 4:09 PM
Gack2000 wrote:
100%
It wouldn't matter, because I have a new sprocket coming in. This one's a little bit rusty
6/22/2017 4:40 PM
Gack2000 wrote:
100%
It could still matter-as it could damage your spindle (rust tells me a steel sprocket).
It could also warp and wreck your chain, or cause intense tight spots that blow driver bearings out.
I would check locally for one. How have you been riding without it? Unless the sprocket you have is something YOU put on the bike?
6/22/2017 10:42 PM
Don't ride your bike without it. Your sprocket won't sit central, so, as Dave said, you'll have a really loose spot and a tight spot. The sprocket will wobble no matter how much you tighten the bolts. It's just a ball ache waiting to happen really
6/23/2017 5:31 AM
Sounds like a terrible idea. Hit your local bike shop and pay the $5 for a new one.
6/23/2017 9:34 AM
My old bike didnt have a top hat spacer on my sprocket and one day while riding the chain came off (happened a lot on the count my sprocket moved SO MUCH) and I crashed HARD AS HELL. This was 2 years ago and my knee has never been the same since. I'm never going without one of those again
BOTTOM TEXT
6/23/2017 11:47 AM
Sprocket adapter. Some call it hat washer but make sure you get the right inner diamater size. "19 or 22mm"
6/24/2017 3:20 AM
DanTheBikerMan wrote:
If it is this, you might be fine for a little bit. Granted, your sprocket will move around and mess stuff up. So get one as ...more
Yes
