Can someone explain this compression cap?
8/22/2017 12:02 AM
Can you just use a normal allen to tighten? If so why did they set it off to the side???
8/22/2017 12:13 AM
Yes, but it will only work with Odyssey forks.
8/22/2017 12:32 AM
Or forks with the same thread.
It's off centre so you can run a front brake cable through the hole if you have a front brake
8/22/2017 6:17 AM
Edited Date/Time: 8/22/2017 6:17 AM
As grumpySteve already said....
Yes you can use an allen key.
It's offset to allow you to run a front brake cable.
