Chain issues
4/23/2018 12:03 PM
Hey guys, hoping someone might have a suggestion for a problem I'm having. I've got a tight and loose spot in my chain. My sprocket can't be ovalised because I fit a brand new sprocket, chain and hub (driver) all at the same time. Any ideas what could be the problem?
4/23/2018 12:07 PM
Sprocket on the correct sized spacer for the spindle? If the sprocket is a steel stamped one it could be out of round.
Could be a stretched chain.
Take the chain off and spin your cranks-if it moves up and down make sure it is centered correctly on a spacer that is correct size. If it does not move up and down, then it is your driver or chain.
4/23/2018 12:54 PM
Could ...more
Yeah spacer is correct. The thing that is confusing me is that I got the sprocket, chain and hub all at the same time (all brand new) and as soon as I fit them to my bike I was having this problem. It isn't anything extreme so I haven't been too worried about it but it is slightly annoying as it isn't as smooth as it could be to ride
4/23/2018 1:01 PM
Have you tried tightening the crank bolt before tightening the sprocket bolt?
4/23/2018 1:03 PM
Yeah man, several times just in case I goofed sad
4/23/2018 1:25 PM
Edited Date/Time: 4/23/2018 1:29 PM
Don't fully tighten the sprocket bolt until you've set-up your desired chain tension.
Once desired chain tension has been achieved "slowly" rotate your cranks a few times... check for severe tight/ loose spot... If there isn't a severe tight/ loose spot, rotate cranks a few times again and then fully tighten your sprocket bolt.
This will allow your bolt drive sprocket to self adjust on your crank arm. This may take several attempts...
4/23/2018 1:33 PM
Once desired chain tension has been ...more
I'll definitely give this a go, thanks for the tip. Fingers crossed it works!
