Chain length issue
7/5/2018 4:36 PM
Whats up pimps and gangsters. Uhh basically i’m running a fit mac frame and the back end feels way too long so I want to slam my wheel. I bought my shadow raptor used so it has like a 9 or 10 tooth cog and i have a 25 sprocket. Basically if i slam my wheel with current chain length its way too loose to even ride and if I take out a link its too short to fit. What do i do
13 years old
7/5/2018 5:03 PM
Edited Date/Time: 7/5/2018 5:05 PM
Half link
Different sprocket
Grind down your drop outs
I'm in the same place. Its lame my wheels like at the end of my dropouts if I take a link out it's so tight I can barely pedal. 25/9 is pretty much the standard and frames are still made that you can't slam your wheel. Now I have to ride like 23/9 or cut my frame down
Rant stops here.
Also nice to see you still got a bike dude, frames a lot better too
7/5/2018 5:11 PM
Four wrote:
Half link
Different sprocket
I'm in the same place. Its lame my wheels like at the end of my ...more
Im getting clips this weekend hehe
13 years old
7/5/2018 5:45 PM
Same. 25/9 and have my wheel coming out the edge of my dropouts since changing over frame today...when it ends up (not) working out like this it’s because the frame was made measured to run a 10t driver...I think...don’t know of any 26t (guarded) sprockets which would probably be an easy solution too...am just going to grind the dropouts in a quarter inch. If I remember right think that a 28t worked with a half link.
account here is less about my and more about bike
7/5/2018 6:07 PM
Edited Date/Time: 7/5/2018 6:08 PM
You have a 25-9, and you need probably 2 of these. And problem solved. Shop around some mail order places have them for $1.00-2.00 each. Just depends
7/5/2018 7:04 PM
What Fit Mac frame do you have?
I think the V1 had a 13.35" CS slammed and the V2 has a 13.5" CS slammed.
7/5/2018 7:08 PM
On all the Fit Mac v1's i had i ran 28/9 and almost always slammed it almost perfectly
7/5/2018 8:14 PM
This.
28/9: 13.375 W/Out Half Link
25/10: 13.375 W/ Half Link
If it's the V2 (13.5" CS):
30/10: 13.50 W/ Half Link
28/10: 13.50 W/ Half Link
27/9: 13.50 W/Out Half Link
25/9: 13.50 W/ Half Link
7/5/2018 8:38 PM
Idk i bought it off of crazysteve
13 years old
7/5/2018 8:39 PM
My bike just feels like a fucking beach cruiser i rode all my friend’s bikes and they can like pop off their backwheel and its so much more fun
13 years old
7/5/2018 9:52 PM
Edited Date/Time: 7/5/2018 9:55 PM
Slam your back wheel and measure from the center of the sprocket bolt to the center of your rear axle/ bolt.
7/5/2018 9:58 PM
Longer chainstays = higher hops. Embrace it
7/5/2018 10:08 PM
JUST GET a half link chain OR get 2-3 half links and a chain breaker. I would say get the Shadow with tool combo but not sure what budget you have. Considering a normal chain breaker with break a half link...but it will only do it a few times. After that it gets iffy about it snapping. Here are some very helpful parts and tools for getting your back wheel slammed or whatever perfect chain tension. Should help get you started
https://www.acebmx.com/chains-bmx-c-23/shadow-conspiracy-interlock-v2-pro-grade-chain-breaker-combo-p-1361.html
https://www.acebmx.com/chains-bmx-c-23/salt-plus-warlock-18-half-link-chain-p-12211.html
Half link built in
https://www.acebmx.com/chains-bmx-c-23/odyssey-bluebird-chain-p-1687.html
Great chain and no breaker needed
https://www.acebmx.com/chains-bmx-c-23/odyssey-key-chain-hollow-or-solid-pin-p-6131.html
Can break a 1/2 link
https://www.acebmx.com/tools-bike-c-40/odyssey-chain-breaker-tool-bluebird-p-12561.html
7/5/2018 10:11 PM
I just got my Merritt HL1 chain. My first half link and it's amazing. Strong af. Makes it possible to slam my wheel on my Skapegoat. And it's clean.
7/5/2018 10:14 PM
I don’t know if that’s fact or not. Seeing I have rode bikes with 14+ rear ends and 13-something and either one I can hop bar height or more depending on what it is. Seeing they have a ledge at the local high school that is way up and I can get onto it but it takes serious technique and pretty good upper body strength. But, just normal stuff that’s 2’ or so is easy. I don’t know if it’s me or what but I can’t really just hop on flat and get really high. But over or onto something it’s 100% different. Never figured that out ??
