Chain wobble
2/14/2017 5:53 PM
How much is your chain supposed to wobble? Is it normal for it to make noise after jumps
2/14/2017 6:20 PM
If it is lubed(actual chain lube, not WD-40 or the likes) and it is at the correct tension, there should be no noise from it.
2/14/2017 7:36 PM
ya just make sure its lubed and tite
2/15/2017 5:07 AM
What about noise from it smacking the metal on my bike?
2/15/2017 6:05 AM
Means it's not tight enough, the chain should be just tight enough that there's no wobble and just loose enough that it doesn't make it harder to spin the cranks.
2/15/2017 6:25 AM
No it shouldn't make any noise. If it's slapping against your frame, it will eventually wear a hole right through your chainstay. I like my chain pretty loose. Just loose enough that it doesn't slap when I drop my bike.
2/15/2017 10:05 PM
As others have said, check the chain tension. If that doesn't eliminate the problem, make sure your chain alignment is fairly straight and not too far off.
