DeviantBMX123 wrote:
well clears are almost automatically work better because they are softer. BUT the clears are oddyssey. soo other than being a TINY bit longer they are the exact same as the slim by fours. and the dual compound arent as soft. they might flex a bit harder giving a better pinch but if the clears aren't grabbing then i dont know how well a harder compound well... Out of these two.. its a toss up... i think they will both perform very similar to any aftermarket pad in clear.
i dont mean to beat the dead horse(or however the fuck the sying goes) but will u post a pic of the brakes with the pads toed in and with the pads all the way against the rim. I really dont mean to be a dick but i still say there is something else wrong.
I toed them first with a dime, no noticeable change
then a nickel, they worked noticeably WORSE
finally a pad spacer (like 2 nickels thick), they didnt work whatsoever. Barely slowed me down.
They work fine and do the job when theyre not toed, but they dont lock the wheel like alot of other people's do. Most of the time when trying fufanus/abubakas I will fall because I start rolling back unexpectedly. This was never a problem with my..
Chrome Odyssey Hazard + Purple Fly Zepatas
Teal Odyssey Hazard + Clear Odyssey Pads
Mint Alienation 7up (brand new) + Clear Odyssey Pads
My lever/cable/gyro set up was exactly the same with all of these and worked like a dream. I am still on the 7up except now it no longer has paint on the sidewalls. It worked perfectly before the paint rubbed off.
I have a feeling its just the material these rims are made of, I believe its alot less grainy than 6061 therefore alot less friction. I tried sanding my rim and it barely helped.
Anyway, youre totally steering off topic here. I have diagnosed the problem, its between my pads and my rim. Everything else is set up like sex and even worked perfectly with different rims/pads. I just want to know which pads have the best chance of fixing the problem.
