I always have a loose sprocket bolt and every time I tighten it up the next day it will be loose and then if I thighten to much the whole set up doesn't move at all! I don't know what it do
? your sprocket isn't supposed to move, that's why the bolt's there.
thread lock thread lock thread lock
Youtube
Instagram: @joelfiest
Twitter @joelfiest9
MidWestBMX wrote:? your sprocket isn't supposed to move, that's why the bolt's there.
Oh I meant the cranks and spindal bolt, when I tighten nothing moves(cranks arms,spindal)
Tightening your sprocket bolt shouldn't affect your cranks spinning
In your bottom bracket between the bearings, there is supposed to be a spacer that spans from one bearing to the next.
That spacer is there to keep the bearings from seizing up if you over tighten your spindle bolt.
If that spacer isn't there or is too short, and you over tighten the bolt, your cranks wont spin well if at all.
Make sure you have the right spacer in there, then tighten you spindle bolts, then your pinch bolts (unless they are 48spline)
If that don't work take pictures of your setup and explain better what's going on.
Good luck.
probably don't have enough spacers.
try the spacer. if not. loctite
skooter... dont be a pussy
You've probably worn the splines on your crank or spindle. When you ride a loose crank the splines rub against each other and eventually wear out.
Once they are worn there's not much you can do except keep tightening it. If this is the situation the best fix is new cranks.
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
