Crank Length
3/14/2011 5:16 AM
I know it affects how hard the gearing feels, but is it longer = harder or shorter = harder?
3/14/2011 5:17 AM
shorter is harder.
Get off your little kid bikes and get a CRUISER!
3/14/2011 5:18 AM
Longer would be easier, as you have more leverage to to push with,
Say if you put 10 kg at a lever a meter long, then put it on a lever 2 meters long, it would be able to lift more on the 2 meter long lever.
3/14/2011 5:21 AM
Thanks guys, i wanted to know why so many pros seem to have 180 mm rather than 175mm, i will stick to 175 i think
3/14/2011 5:28 AM
180 mm just seems like it'd be annoying to catch some tricks with.
3/14/2011 5:38 AM
yeah i suppose it would be good if you ran like 28/9 or something
3/14/2011 6:16 AM
I've run everything from 170 to 185 and I can tell you that every person has a "magic" number where things work best for them. Mine is 175. A lot of it too has to do with height of a person. If you are taller, going longer feels better usually, as your feet aren't rotating quite as fast.
3/14/2011 8:27 AM
175 is perfect not to small and not to big!
[b]( . Y . )` ~ ~ ` ~
3/14/2011 10:58 AM
no, you would be able to lift it easier, not higher. longer levers take up the work. it simple machines.
IN NOMINE SATANUS
3/14/2011 11:00 AM
i have 175s tho and my bro has 180s and i dont feel a difference. i dont think a few mm really mattters.
IN NOMINE SATANUS
3/14/2011 3:24 PM
thanks guys!
3/14/2011 5:37 PM
175mm for life!
3/14/2011 5:49 PM
180mm feels nice to me
SUNDAY OG
Sign by Danasoft - Get Your Sign
3/14/2011 7:58 PM
Measure Your Inseam Length And Go By The Chart Below To Find The Crank Arm Size That Best Fits You.
20" 140mm
21" 145mm
22" 150mm
23" 155mm
24" 160mm
25" 162mm
26" 166mm
27" 171mm
28" 175mm
29" 177mm
30" 180mm
31" 182mm
32" 185mm
34" 190mm
