Crank help
8/8/2009 12:38 PM
Ok so where my pedals screw in stripped my cranks (stock element 08) so i took cranks off a fit series 1 . Just the spindle n crank arms because the fit has amer. BB. When i tried to put the profile cranks in they wobble a bit unlike the eastern spindle which needs to b put in by hammer cuz its snug. Theres a silver spacer in the bb which is stock with the element nd the profile spindle is a bit less beefy then the eastern ( just the part that remains in bb. WHAT DO I DO? do need whole new bb this bikes new or will the gold spacer hold it snug in the bb?
8/8/2009 1:08 PM
noone knows??ight then
8/8/2009 1:11 PM
What size is the profile spindle?
Refs: irideafly, nikpeterson, spikez5, \BMX-1995/
8/8/2009 1:24 PM
The spindles are different sizes.
8/8/2009 1:29 PM
haha the eastern was a 22mm probrobly
profiles are 19mm
#Merica.
8/8/2009 2:33 PM
idk the size
8/8/2009 2:35 PM
Look at them and see if they are different sizes because that is probably the problem.
8/8/2009 2:48 PM
how do i find our for myself weather its 19 20 22
8/8/2009 3:16 PM
nd waht does mm stand for maybe i should take my own measurements as now i dont know wat size spindle fit in my bike nd cant fet up nd running till k know nd buy cranks accordingly
8/8/2009 3:19 PM
Get metric ruler and measure it.
8/8/2009 3:24 PM
what does mm stand for?
millimetre.
you should be able to measure the spindle with a ruler, or even just look at it ,its 4mm difference pretty easy to spot
8/8/2009 3:49 PM
its not the length im havin trouble with its the diameter of the spindle
8/8/2009 3:57 PM
here is how to fix it.
Take the fit bb, Take the fit bearings out of the American shell. That will make the bb work as a mid. So now you can install all the fit parts and it should fix your problem.
Tell me if this helped you.
8/8/2009 3:57 PM
idk
My refs ?... Nigga just ask about me
8/8/2009 3:59 PM
then measure the diametre, is it that hard to measure something 19mm wide? and there is a tool for measuring outside and inside diametre called a vernier caliper, but you probably dont have one.
8/8/2009 3:59 PM
sure ^
8/8/2009 4:11 PM
its a spanish bb i got in my element
8/8/2009 4:13 PM
Never mind then.
8/8/2009 4:15 PM
imagine puttin a 10mm axle into a 14mm dropout thats my prob but the cumsmuggler that answerd a while ago doesnt get idk how to measure the bb hole so can get a seta cranks whose spindle will fit properly
8/8/2009 4:21 PM
ya
8/8/2009 4:51 PM
im thinkin its a 20mm cuz i measured diameter of bb hole its 2 cm
8/8/2009 5:05 PM
can you even get 20mm cranks?
8/8/2009 5:27 PM
i think
8/8/2009 5:34 PM
i think you should do an accurate measure, coz it could be misread from 19mm or you may not have measured from the furthest points on the circle and it may be 22?
8/8/2009 5:55 PM
ya the diamiter of spindals are 19,20 or 22 you probably wen trom 19 to a 22 you either need a new bb or a new spindal
ref(s): evenwest94
