Crank questions
4/10/2017 4:30 PM
Hey everyone, My threading is stripped on my crank that im using currently, a pedal wont even screw onto it. I have a prebuilt Sunday Blueprint 2016, I was looking at Saltplus groove cranks, I believe it comes with BB, If not, is there a specific BB size i need? also is there a chance it wont fit my bike? Are these cranks worth the money compared to the complete bike cranks?
4/10/2017 4:58 PM
Find out and see what crank spindle size it is , most likely 19mm or 22mm . If it's a 22mm and you had 19mm , you'll need a new BB to accommodate it . Also most sprockets are 24mm and have adapters for 22mm and 19mm spindles , but some are a specific size , so find out and see .
4/10/2017 5:30 PM
They come with a 19mm Mid BB, the exact same as the stock one on your bike. They should work fine.
4/10/2017 5:46 PM
Brayden_Buckingham wrote:
Find out and see what crank spindle size it is , most likely 19mm or 22mm . If it's a 22mm and you had 19mm , you'll need a ...more
This. As a complete, it is a 19mm, with an 8 spline spindle.
As long as you get something 19mm you will be fine.
4/10/2017 6:43 PM
Actually, the Sunday blueprint had an unsealed American bottom bracket.
4/10/2017 7:18 PM
Quoting: http://www.sundaybikes.com/bikes/archive/2016-completes/blueprint/2016-blueprint-silver/
FRAME: 20” TT, Hi Ten Steel
FORK: 2PC Steerer tube, Welded Pre-load bolt
HANDLEBAR: Sunday 28.5” Width, 9” Rise, 12° Back, 4° Upsweep
STEM: Sunday Freeze Front-load Stem 48mm
HEADSET: Traditional 1-1/8”
HEADSET CAP: Alloy Cap w/ star nut
BRAKE: Odyssey Springfield
BRAKE CABLE: Odyssey Quik Slic
BRAKE LEVER: Alloy
GRIPS: Odyssey Aaron Ross Boss
SEAT: Sunday Cloud Seat and Post combo
SEAT POST: Integrated
SEAT CLAMP: Integrated
SPROCKET: Sunday, 25T, steel
CRANKS: 170mm, 3-piece, Chromoly RHD
BB PARTS: 19mm sealed Mid
PEDALS: Wellgo Plastic
RIMS: 20” rim, 36H
FRONT HUB: Sunday, 36H, Low-flange, Loose-ball
REAR HUB: Sunday, 36H, Unsealed Cassette, 9T
SPOKES: Steel Black
TIRES: Sunday Current 20 x 2.4” (F & R)
CHAIN: KMC Z-410
4/10/2017 7:56 PM
Ohhhh I thought it was a 2017 Sunday blueprint, my bad. That one comes with an unsealed American bottom bracket
4/11/2017 10:50 AM
Are you turning the pedal the correct way? If the thread is just a little messed up you might get away with chasing it with a tap
4/11/2017 12:23 PM
Are you turning the pedal the correct way? If the thread is just a little messed up you might get away with chasing it with a ...more
yep, the pedals are marked Left and Right. The Left pedal (non-drive side) screws in COUNTER-CLOCKWISE!
One way to remember is that the pedal wrench turns towards the front of the bike, on both sides, right or left pedal.
