Can someone say some good, cheap, 19mm cranks?
Deez nuts
I run this crank since 4 years, and still holding up like at the first day.
They have also made a "big brother" version with a 22mm spindle but, you ask for a 19mm (probably to keep your bearings) and it´s large enough, after 4 years of abuse and my 200lbs (90kg) the axle is fine.
Also, glad you can buy on unleaded, I know they do international orders but I personnally don't care about that because I'm in France and there are superquick (If I order now I'll be delivery tomorrow morning !) Now I just hope it won't cost you an arm and legs for shipping. Where are you from ?
I'm in Romania, Baia Mare, but I have an aunt in Paris, so it ships there, and she ships it to me. I don't know if I should get the subprime or syndicate. Both look good.
Deez nuts
The syndicate is a sure value, the subrime looks pretty solid too,thiner and a bit lighter if that matter for you.
Both will do the job but the syndicate will probably survive better in the time because it´s thicker. It can also being a plus if you plan to do crankslides.
