Cranks and sprocket question
3/16/2015 12:47 PM
Edited Date/Time: 3/17/2015 7:33 PM
z
3/16/2015 12:56 PM
DON'T DRILL YOUR CRANKS.
Return the sprocket. Get one that works with socket drive.
3/16/2015 1:09 PM
Can a bolt drive work with a socket drive?
3/16/2015 1:15 PM
If your cranks are threaded for a sprocket bolt (next to RHD on the upper crank arm in this pic) then yes. Otherwise, you need a specific socket drive sprocket.
Odyssey and Tree make socket drive sprockets that I know of.
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
3/16/2015 1:35 PM
united also do
Follow on instagram will follow back.
brandonmorris_
3/16/2015 1:59 PM
Tree makes socket drive sprockets. Why the fuck would you buy a mission sprocket?
3/16/2015 4:55 PM
z
3/16/2015 5:09 PM
Well if your crank arms are crappy redline ones then that means you dont have socket drive cranks. Do you mean spline drive?
3/16/2015 5:25 PM
z
3/16/2015 5:53 PM
ziggy2626 wrote:
z
no you're talking about bolt drive, socket drive is the nonagon thing that holds your sprocket w/o a sprocket bolt, spline drive uses a 48 splined spindle and the sprocket slides onto that. Bolt drive uses a bolt to hold your sprocket in place. So if i am right that little pin would be the bolt that holds your sprocket into place.
3/16/2015 6:00 PM
ziggy2626 wrote:
z
I think I know what your problem is. Your sprocket has a 15/16 bore (24mm), which is where the sprocket slides on to your cranks, and your cranks are more than likely 19mm. Which means your sprocket is too big for your spindle. You'd need a sprocket adapter so your cranks fit on your sprocket. You'd need a 15/16 to a 19mm sprocket adapter for your cranks to work with your sprocket. Hope I could help you lol
3/16/2015 6:27 PM
Coopers25 wrote:
no you're talking about bolt drive, socket drive is the nonagon thing that holds your sprocket w/o a sprocket bolt, spline ...more
z
3/16/2015 10:33 PM
Yeah the pin in your crank arm replaces the sprocket bolt. Something worth upgrading at some point.
Chris
3/17/2015 7:01 AM
What they said. You don't have socket drive. You have some more basic cranks. Your sprocket will work as long as you have the correct spacer for the spindle.
