So I just replaced my hub's driver and I babied it, I mean I always do a good job of de- and re-greasing everything but this driver was a PITA to find (LHD 10t for older ODY driver, had to get help from odyssey who were FANTASTIC in helping me), I greased the inside of the hub (everything with lithium grease) and then wiped it as best I could, I greased the pawls&clip&inside faces and wiped them as best I could, I put all the retention nuts back on and found their proper tightnesses - I then backed-off the nuts a minutiae of a turn as I always do as tightening the dropouts usually pinches them in the slightest bit I find) Anyways I can lift the back wheel from the ground and if I spin it forward with my hand it goes incredibly smooth and spins a while; if I spin it backward, *it does not* even try to pull the pedals backward; my chain is not remotely tight, I left it on the loose side since it was a new driver, and I mean loose; yet I have a problem, for some reason now my cranks are VERY stiff, both forward and backward! Minimal hand pressure was needed to move them and now they feel like I've got my chain pulled tight or I over-tightened the spindle bolts (I didn't touch any of my sprocket or crank hardware I only removed the rear wheel, swapped the driver, put it back in a bit on the loose side both the compression nuts and the chain, yet now I've got stiff cranks and I can only imagine it's because the driver isn't spinning as free as it should but I just cannot see or imagine what interface would be causing this as it's all fresh and greased!
Any help, guesses or wild speculation would be great here!! Maybe there's a 'break-in period with new drivers put into older hubs? I mean, this hub has seen better days lol!!
