Cranks won't come off...
10/12/2013 2:07 PM
I have 48 spline 1664 cranks and they won't come off.... I pulled and pulled. I screwed in a bolt and hammered it like no tommarow that's all I've tryed but is they any other way with out a crank removal device?
Bang Bang bmx
10/12/2013 2:13 PM
Edited Date/Time: 10/12/2013 2:14 PM
will they wiggle at all? I have no clue just keep on banging on them with a hammer if you don't want them. Try to use wd40 or something like that???
10/12/2013 2:15 PM
Have to tried using a metal hammer? usually thwy work better then a rubber mallet but you have to cover the cranks with like a towel or something so you dont fuck them up
Murica bike check
10/12/2013 2:22 PM
handlebar-to-face wrote:
Have to tried using a metal hammer? usually thwy work better then a rubber mallet but you have to cover the cranks with like a ...more
i use a socket extension and a metal hammer and i hammer on the end of the spindle with the socket extension
MIDWEST MOTHER FUCKER
10/12/2013 4:36 PM
jump on the pedals then flip it back over and they should come off.
10/12/2013 4:43 PM
I hammered the shit out of them and pulled like my life depended on it and no theirs no wiggle
Bang Bang bmx
10/12/2013 5:07 PM
Did you weld them on hahaha
Murica bike check
10/12/2013 5:12 PM
Pictures would make this easier.
10/12/2013 5:14 PM
you could cut them off with a saw...
10/12/2013 6:22 PM
grease the threads better next time? use a crank puller?
10/12/2013 6:51 PM
Its important that you use a crank tool to install the cranks. Tapping them on can push them on unevenly and ruin the splines, making them impossible to take off. Also grease you're spindle atleast once a month, eventually that grease can lose its ability to prevent bonding between the spindle and crank.
10/12/2013 6:54 PM
HardBMX_Tim wrote:
Its important that you use a crank tool to install the cranks. Tapping them on can push them on unevenly and ruin the splines, ...more
This. I had some kid come into the bike shop cause his weren't pressed on right & caused them to look bent, or on the wrong spline, but it was really just overlapping splines
Spray some WD40 down in there & let it sit over night or for a few hours AT LEAST. Let it work it's way into the splines & then try beating it out again.
10/12/2013 6:58 PM
sundaybmxRR wrote:
This. I had some kid come into the bike shop cause his weren't pressed on right & caused them to look bent, or on the ...more
I didn't put them on they came on the bike.. Ok I'll try that theirs a little gap that I could put it in and no I didn't weld them on so ya I'll try wd40 itLl help with the rust to
Bang Bang bmx
10/13/2013 1:48 PM
The cranks move an inch then just stoped
Bang Bang bmx
10/13/2013 2:46 PM
Yeaup. WD40 that bitch and it should help
10/13/2013 2:56 PM
This, soak em in it as much as you can and it will start to work
Murica bike check
10/13/2013 3:55 PM
Saiid fuck it went to the bike shop and my friend did it for free he also broke my chain
Bang Bang bmx
10/13/2013 4:26 PM
As in actually broke your chain or took it off with a chain breaker?
10/13/2013 4:38 PM
Chain breaker
Bang Bang bmx
