Cranks wont tighten , HELP
7/28/2011 11:53 AM
I tighten the spindle bolts down and i can push the cranks side to side a little bit. If you pushed on the spindle bolt on the left side it slides a little to the right then you can puch it back the the left side Also the sprocket is loose too, you can like push it a little side to side. Ive tried adding spacers and taking spacers off but i cant seem to get them tight :/ got any ideas?
7/28/2011 12:04 PM
7/28/2011 12:23 PM
take it to your lbs
LIFE BEHIND BARS
7/28/2011 12:30 PM
rideallday661 wrote:
take it to your lbs
this or get a new bike but what brand of cranks r they
Just ride and stop being a DICK to the new kids
7/28/2011 12:42 PM
your cranks need more spacers.
A bike is not a bike if it doesn't have air in the tires.
BSD Front Street Hub Review
Primo Mix Review
Why You WEAR a mouthguard!
Refs.
\BMX-1995/
7/28/2011 12:50 PM
they were stock cranks and stock bb off of a fit str 1 2010
7/28/2011 1:59 PM
Ive tried putting in spacers :|
7/28/2011 3:38 PM
put spacers in till the wiggle goes away try to make the gap distance from the fram to pedal boss equal distance
7/28/2011 5:35 PM
Alright ill just work on it and change things till i get it right
7/28/2011 6:34 PM
moar spacers
FTW!
I'm cooler than a polar bear's toes.
7/28/2011 6:36 PM
bolt stripped or the treads in the spindle are.
Cool story man!
Water Melon Check
Refs: Sire, 2283kdogg, Zerobig13, Ilovemybike22, BmxRida4lyfe
7/28/2011 6:47 PM
ether more spacers, or cut your spindle down a bit
Swoop it motherfuckas
7/28/2011 6:57 PM
That isnt stripped because when i tighten down the bolt with an allen wrench it turns til its tight
7/28/2011 6:59 PM
then whats the problem if it gets tight?
Cool story man!
Water Melon Check
7/28/2011 7:03 PM
I can move the cranks and spindle side to side a little bit? idk how to explain it
7/28/2011 8:58 PM
as in, they slide in the bb from side to side? Or is the bearing like ovalized and it wobbles in the bearing? Dude just take it to the local shop and have 'em look at it and give you their two cents, you don't have to ask them to fix it.
FTW!
7/28/2011 11:31 PM
New Cranks! Stocks are shit :/
DK Socials for 120 on Chain reaction tongue
Decided to burn lots of calories today, so I set a fat kid on fire.
7/28/2011 11:32 PM
I ride stock DK cranks smile
7/29/2011 1:00 PM
its not up and down inside the bb its side to side movement ... and i dont have any money to replace them sad
7/29/2011 1:09 PM
weird. do they have pinch bolts?
7/29/2011 1:12 PM
Yess sir
7/29/2011 3:30 PM
undo the pinch bolts tighten the spindle bolts then re-tighten the pinch bolts and that might work or more spacers
