Credence CCR Odyssey hub
9/7/2017 5:29 PM
I'm thinking of getting a CCR, will my current Ody V3 with the female axle conversion fit with the 3/8 dropouts? It has the collars like this
9/7/2017 5:42 PM
In that picture, one of the bolts looks like a 14mm female and the other looks like a 3/8ths female.
9/7/2017 5:42 PM
Edited Date/Time: 9/7/2017 5:43 PM
Both bolts need to be 3/8ths. Also, it looks like the 3/8ths bolt has a 14mm adapter on the collar. So no, I doubt it would work
9/7/2017 5:46 PM
The Bolts on mine are 3/8ths but the collar has the built in 14mm adapters.
9/7/2017 6:44 PM
No, those collars are 14mm and designed to slide into 14mm dropouts. The Credence frame has 3/8" dropouts so it wouldn't work without grinding them off or something
9/7/2017 6:59 PM
sundaybmxRR wrote:
No, those collars are 14mm and designed to slide into 14mm dropouts. The Credence frame has 3/8" dropouts so it wouldn't work ...more
That is what I assumed, thanks.
9/7/2017 11:20 PM
So, the bolt itself has the collar that slides onto the dropouts? Not the hub? Get different bolts and it'll fit.
9/8/2017 5:59 AM
No, the hub has press on collars instead of thread on cones and the collars have the 14mm adapters built in. I have not been able to find replacement collars without the 14mm shoulder.
9/8/2017 9:32 AM
Cut it off if you can? There's plenty of hubs on the market that work that way
9/8/2017 12:13 PM
scrub74 wrote:
No, the hub has press on collars instead of thread on cones and the collars have the 14mm adapters built in. I have not been ...more
9/8/2017 6:53 PM
Just get the new Credence Black Magic Frame, so you can rock 14mm dropouts and a huge sprocket. lol
9/8/2017 8:11 PM
Back end of that black magic is looooooooooooong!
