Cult Mix
1/25/2014 8:19 PM
Ya I know it's a match, but it's a mix inside..
1) I was wondering what the best hub guards would be under 30$? I was looking at the Bsd ones... I also looked at the S&M ones but there to expensive for me right now..
2) Does anyone sell the Cult Match laced to the Cult match rim.. Both in orange, I know Dans has them in black hub to orange rims. I'm talking about pre made wheels.
3) Is it true Female? Or She male
Bang Bang bmx
1/25/2014 8:28 PM
1- Try the Bonedeth guard, it's chromoly & under $30, would be better in the long run as it won't deform like aluminum ones do. I have the S&M & it's great, almost 2 years old now & if I like lightly sanded it & threw a fresh coat of paint on it, it would look brand new. aside from one small spot. Whatever you do, do NOT get the Cult Match guard "made" for it. It has no threads, which to me is retarded because it's for a threaded axle hub
2- Just get it laced for free by ordering everything there, I added it up and with regular black sapim spokes, it came out to $197.58 for the wheel since the rim is on sale
3-She-male
1/25/2014 9:28 PM
i think its male actually
Old bike VVV
California Living
1/25/2014 9:30 PM
sundaybmxRR wrote:
1- Try the Bonedeth guard, it's chromoly & under $30, would be better in the long run as it won't deform like aluminum ...more
Thanks and I was thinking empire, but it would cost like 20$ more shipping
Bang Bang bmx
1/25/2014 9:31 PM
Albes? Use code Vitalboard & get a discount
1/26/2014 12:49 AM
Does anyone know if the dailygrind hubguard works on the match hub? I want to replace my fbm with a chromoly guard and have heard some people on here say they had spacing issues, etc.
1/26/2014 2:53 AM
the cult match v2 guard (fc one) is threaded, so that might work?
NEW Bike check
Raw Clips Edit
1/26/2014 6:50 AM
What hub guard should I use In the front then? The porn hub guard is only for the back
Bang Bang bmx
1/27/2014 10:41 AM
Don't get the match rim mine dents really easily
1/27/2014 2:41 PM
How do you dent a rim? Like wtf where you doing the dent a rim..
Bang Bang bmx
1/27/2014 2:43 PM
it's not that hard.. a friend of mine has a few dents in his cult match rim too. for example, when you air out and end up doing a kind of a disaster, or when you are hopping wrong up a curb and your rear wheel hits it
1/27/2014 2:56 PM
ivancuestabmx wrote:
it's not that hard.. a friend of mine has a few dents in his cult match rim too. for example, when you air out and end up ...more
That's not the rim's fault, that's from running low tire pressure. I run lower than most people do for tire pressure, 60 or 50 usually, and one time I slammed my bike against a guard rail cause I was pissed off & dented the shit out of it. A G-Sport rim. any rim can have that happen to it if you hit it hard enough & run low tire pressure
1/27/2014 3:03 PM
sundaybmxRR wrote:
That's not the rim's fault, that's from running low tire pressure. I run lower than most people do for tire pressure, 60 or 50 ...more
yeah i know, i wasn't saying it was the rim's fault, but if you don't run a high pressure, it can happen easily
1/27/2014 3:18 PM
Daily Grind LT is chromoly, universal, and only $19. I love mine so far. Slides like butter and protects the wide flange of my Gsport Ratchet. Its also a bit shallower than most guards, HOPEFULLY eliminating the need for an extra washer and frame spreading.
If youre fine with a alloy w/ plastic sleeve, the Animal PYN is real cheap and replaces your non drive hardware, so no frame spreading. I had one and custom tapped it to work with my Remix (different axle than mix/match) and it held up great. Sleeve eventually cracked but new ones are only $3 AND animal announced they are releasing a chromoly sleeve for it in the near future.
Either of these are great choices and MUCH cheaper than ever other guard of their kind.
1/27/2014 3:20 PM
And if your front hub has a 15mm center axle, the Daily Grind Front (chromoly) will fit it and is also cheaper than mosy guards ($15)
