Cult control 2014 or Fit dugan 1????
5/23/2014 7:17 AM
hi guys,
i am going to buy a new bike but which is te best bike of these two?
here are the specs of the cult:
BMX Frame: 4130 full crmo frame, removable pivots & guides
Top Tube (TT): 20.75
BMX Fork: full crmo fork, 1pc crmo steerer
BMX Bar: full 4130 crmo bar
Height: 9.0
Width: 30.0
Grips: Cult x Vans "Waffle" grips
Stem: Cult "Salvation" style top loading stem, 52 reach
Headset: int. headset, sealed bearing
Gyro: no / holes for removable gyro tabs
Brake Lever: alloy
Brake: 990 u-brake
Bottom Bracket: mid size, press fit, sealed bearing
Pedals: Cult nylon pedals
Chain: Cult "510" chain
Sprocket: Cult "Member" style aluminium sprocket 25t
Crank: Cult heat treated crmo 3pc crank 170
Hub (front): Cult "Match" alloy hub, sb, 3/8" female bolts, 36h
Hub (rear): cassette hub, sb, 9t, 14mm axle, 36h
Driver:
Rim (front): single wall aluminium rim
Rim (rear): double wall aluminum rim
Seat: Cult "DAK" pivotal seat
Seat Post: alloy, pivotal
Seat Clamp: integrated slim seat clamp
Tire (front): Cult tires "Dehart"
Width: 2.35
Tire (rear): Cult tires "Dehart"
Width: 2.2
Pegs: no
and here are the specs of the fit:
BMX Frame: 4130 CrMo Frontend
Top Tube (TT): 20.25"
Chain Stay (CS): 13.1"
Head Tube (HA): 75°
Seat Tube (SA): 71°
BB Height: 13.1"
Standover: 8.6"
BMX Fork: 4130 CrMo steerer, tapered legs
BMX Bar: 2-piece
Height: 8.375"
Width: 28.5"
Grips: Fit "Team" Grips
Stem: Alloy, Frontload, 50mm reach
Headset: integrated, sealed bearing
Brake Lever: Alloy
Brake: 990 U-Brake, Alloy, Soft Compound Pads
Bottom Bracket: MidBB, sealed bearing
Pedals: Odyssey "Twisted" Pedals, PVC
Chain: KMC "Z410H" Chain
Sprocket: Fit "Key" Sprocket, 4130 CrMo, 25T
Crank: Fit "Indented" Crank, 4130 CrMo, 170mm, 8 Spline
Hub (front): Alloy, sealed bearing, 3/8" (10mm) axle
Hub (rear): sealed bearing, 14mm axle
Driver: 9T, 1-piece
Rim (front): Revenge "SW1" Rim, 36H
Rim (rear): Revenge "SW1" Rim, 36H
Seat: Fit "Lo-Bolt" Seat, Pivotal, perforated
Seat Post: Pivotal, 200mm
Tire (front): Fit "OEM" Tire
Width: 2.4"
Tire (rear): Fit "OEM" Tire
Width: 2.4"
Pegs: -
5/23/2014 7:43 AM
The Fit 1's are for beginners. The Cult Control is for more advanced riders. So yeah, the Cult is "better" in this match up, but is more comparable to the Fit 2's that have similar specs.
5/23/2014 7:45 AM
get the cult. much much better
5/23/2014 7:45 AM
Fondue wrote:
The Fit 1's are for beginners. The Cult Control is for more advanced riders. So yeah, the Cult is "better" in this match up, ...more
okey but the cult has a discount so it is the same prize as the fit
5/23/2014 7:53 AM
Discounts don't change the specs. The Cult is going to be a good bike regardless. The Fit 1's are good for beginners is all. You're basically comparing apples to oranges and wanting to know which is better.
5/23/2014 7:58 AM
Just get the cult
IG
@curtis_cantbmxwell
5/23/2014 8:31 AM
THe cult is better, if you buy from danscop put the 4431 code.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
