3/29/2019 6:24 AM
Edited Date/Time: 3/29/2019 6:26 AM
When I run it, M2 lever, M2 upper cable, Odyssey GTX R gyro, dual lower cables (I use derailleur inner wires and 4mm housing cause it is cheap) and I use Bike Aid dry Moly lube in all housing and put a thin layer of grease on the wires themselves, Odyssey London Mod, then I run more housing and some zip ties to make a cross/"X" BEHIND the seat tube so the cables pull along pivot of the brake arms. Seems to help the braking be more consistent than just a straight pull dual cable setup. And a Diatech Fiesta brake from like 2004 or so that came with a fork from Dans.
(this is on an old frame I no longer have, but I still use the same setup.)
But right now I am rocking a straight cable setup.
