Detangler on a Fit VH1?
8/6/2017 11:29 AM
Anyone know if you can mount a detangler on a Fit Bike Co VH1?
8/6/2017 12:35 PM
Should be able to
8/6/2017 8:22 PM
If your head tube is drilled for tabs, then yes.
8/7/2017 6:58 AM
They make parts that don't require the drilled in tabs. Old school
8/7/2017 9:31 AM
They don't work with integrated headsets
8/8/2017 4:43 PM
By drilled in do you mean the two small vertical holes on either side of the headtube
8/9/2017 5:05 AM
yes
8/9/2017 1:57 PM
What parts will I need
8/9/2017 2:35 PM
You'll need the mounts that bolt to the headtube, the floating spinny plate, a top plate, an upper cable, and a lower cable. You'll need to remove a headset spacer to fit the top plate, and you need enough room on your steerer tube to accommodate those parts.
