Does cold affect bmx parts?
1/25/2014 7:19 AM
i keep my bike in a garage and its quite cold there..will this have some kind of effect on my bike
1/25/2014 7:31 AM
I doubt it, unless you live in like Antarctica and its like 60 below zero everyday it should be fine
Murica bike check
1/25/2014 7:42 AM
It does have an affect, yes. Steel is a fairly good conductor of heat and therefore has the undesired effect of giving your hand a chilly feeling if you touch your frame when kept in a cold area.
1/25/2014 9:17 AM
yeah thats what i was thinking..thanks
1/25/2014 9:17 AM
BMX_Forever wrote:
It does have an affect, yes. Steel is a fairly good conductor of heat and therefore has the undesired effect of giving your ...more
i could live with that :D
1/25/2014 10:25 AM
Your tires will deflate quicker in the cold but that's about it, I heard brake cables don't work as well if they're really cold too but I'm not positive on that
1/25/2014 11:02 AM
Well, metals athomes are closer in cold temperatures, but i dont really think that it makes a noticiable effect.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
1/26/2014 10:48 AM
sundaybmxRR wrote:
Your tires will deflate quicker in the cold but that's about it, I heard brake cables don't work as well if they're really ...more
This is true, the lubrication thickens (or in som cases can freeze up) causing stiffer or locked up braking if it is cold enough.
1/26/2014 2:07 PM
Tire pressure definitely drops, grease thickens up, and parts like grips and seat stiffen up.
1/29/2014 1:59 PM
The cold won't do much, but you need to be careful of moisture, especially once it starts to warm up to avoid rust.
Your bike will definitely be happier if you can keep it inside somewhere dry, but if not possible the garage is much better than outside!
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
1/29/2014 2:03 PM
Put a towel around your grips to keep them getting moist/stiff
I'm gonna need bigger bars
