Dream bike check
5/1/2014 1:46 PM
Edited Date/Time: 5/1/2014 1:47 PM
This is my dream bike.
Here's the frame specs.
Summary:
Design Frame Geometry (step 1) Modify
75.5 Degree Head Tube Angle Headtube Angle: 75.5 Degree Head Tube Angle
20.5" Top Tube Length Top Tube Length: 20.5" Top Tube Length
70 Degree Seat Tube Angle Seat Tube Angle: 70 Degree Seat Tube Angle
11.625" Bottom Bracket Height Bottom Bracket Height: 11.625" Bottom Bracket Height
9" Standover Height Standover Height: 9" Standover Height
13.25" Chain Stay Length Chain Stay Length: 13.25" Chain Stay Length
Standard 2.35 Tire Clearance Tire Clearance Required: Standard 2.35 Tire Clearance
Design Front Triangle (step 2) Modify
1-1/8" Integrated Headtube with Gyro Mounting holes Headtube: 1-1/8" Integrated Headtube with Gyro Mounting holes
1-3/8" OD Top Tube Top Tube: 1-3/8" OD Top Tube
Clock Hand Top Tube Gusset Top Tube Gusset: Clock Hand Top Tube Gusset
1-1/4" OD Down Tube Down Tube: 1-1/4" OD Down Tube
Mid Bottom Bracket Bottom Bracket: Mid Bottom Bracket
Internally Butted Seat Tube Seat Tube: Internally Butted Seat Tube
Integrated Clamp Top of Seat Tube: Integrated Clamp
Price: $5.00
Round Top Tube Squashed or Round Top Tube: Round Top Tube
Design Rear End (step 3) Modify
3/4" OD x 0.049" wall Seat Stays Seat Stay Tubing: 3/4" OD x 0.049" wall Seat Stays
3/4" OD Tube Seat Stay Bridge Seat Stay Bridge: 3/4" OD Tube Seat Stay Bridge
3/4" OD x 0.049" wall tapered to 5/8" Chain Stays Chain Stay Tubing: 3/4" OD x 0.049" wall tapered to 5/8" Chain Stays
Double Bend Chain Stays Chain Stay Style: Double Bend Chain Stays
3/4" OD Tube Chain Stay Bridge Chain Stay Bridge: 3/4" OD Tube Chain Stay Bridge
Capped Stays Capped or Uncapped Stays: Capped Stays
Howler Style Dropouts Dropouts: Howler Style Dropouts
Select Brakes (step 4) Modify
Seat Stay Brakes Brake Location: Seat Stay Brakes
Removable 990 Brake Mounts Brake Type: Removable 990 Brake Mounts
Price: $10.00
No Cable Guides Cable Guide: No Cable Guides
Removable Cable Stop Cable Stop: Removable Cable Stop
Select Paint (step 5) Modify
Clear Powder Coat Paint: Clear Powder Coat
What's you guy's dream bike?
IG: therealclintvessey
{\_/}
5/1/2014 1:50 PM
Nice, but whats the point on the suday freeze stem, vandero v2 hub, and twisted pc pedals? There are much better products out there.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
5/1/2014 2:03 PM
T-rider wrote:
Nice, but whats the point on the suday freeze stem, vandero v2 hub, and twisted pc pedals? There are much better products out ...more
Idk, for those I just picked some parts because I haven't really though too hard about what stem and front hub i want. I do want the twisted PCs because I like them.
{\_/}
5/1/2014 2:05 PM
And I also want the rear hub to be LHD (I know they don't make those, but it's a dream bike)
{\_/}
5/1/2014 2:19 PM
Shortdude wrote:
Idk, for those I just picked some parts because I haven't really though too hard about what stem and front hub i want. I do ...more
DOesnt take to much to think about a gsport simian, and a cnc´ed stem, like fit high stem....
RIDE OR DIE
THE ROUTER
5/1/2014 2:36 PM
Uh, why would your downtube be a smaller diameter than your top tube? 1 1/4" down tube would be weaker than Sickdude.
5/1/2014 2:57 PM
Oh I meant it to be the other way around, my bad. 1/4 tt and 3/8 dt.
{\_/}
5/1/2014 4:42 PM
I will post mine tomorrow when im with my PC.
RIDE OR DIE
THE ROUTER
5/1/2014 5:06 PM
The Vandero2 is a great hub. 17mm center axle, much stronger than 15mm in most female hubs. Im not positive about the bearings it uses, but I believe they are just as thick as 6902s, so they are no weaker. Uses Gsport axle bolts aswell.
But I agree, I would think for a "dream bike" you wouldn't want a budget stem and cheap pedals.
Also, if youre getting a custom frame, why have removeable brake mounts? If youre going to run brakes, get welded mounts. If not, dont get them at all. Only reason frames come with removeable mounts is because some people want mounts and some dont Theres no true advantage to them, and in my experience have only made installing brakes a huge pain in the ass. Removeable tabs if you are running brakes, to accommodate different styles of brakes if you decide to change it up.
But I could have spent probably an extra $70 on tires, grips, and paint stripper and had this exact color scheme lol.
5/1/2014 6:56 PM
My bike now with TI spokes
My bike is dialed. Can't wait for my Stranger Thrash Bars.
5/2/2014 2:08 AM
Edited Date/Time: 5/2/2014 2:10 AM
HardBMX_Tim wrote:
The Vandero2 is a great hub. 17mm center axle, much stronger than 15mm in most female hubs. Im not positive about the bearings ...more
I know, i own dne with out problems, but with dream bike check id think in the best shit ever done.
RIDE OR DIE
THE ROUTER
5/2/2014 4:09 AM
Only hubs I really see better than the Vandero are Gsport, Tree, and Primo. Its underestimated but the Vandero2 really is a good hub. Better than most on the market.
5/2/2014 8:02 AM
I'd want removable brake hardware just in case I ever wanted to run brakes.
{\_/}
