Drive side hub guards
1/22/2015 11:59 AM
Ok I bought a daily grind drive side hub gaurd and when I put it on and tighten it my chain always comes lose so I think I might need to get a better one or if any you guys knows what's the problem
1/22/2015 11:59 AM
And it comes so lose that my chain pops of my sprocket
1/22/2015 1:25 PM
Take a close up photo of how it's installed and post it here. Sounds like you have something tightening up against something else preventing the wheel from actually being tight. (That may not make a lot of sense but could be explained better if you provide a visual)
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
1/22/2015 1:28 PM
transition_chris wrote:
Take a close up photo of how it's installed and post it here. Sounds like you have something tightening up against something ...more
Ok brb
1/22/2015 2:00 PM
1/22/2015 2:01 PM
That's how I put it on then it gets real lose and my chain falls off
1/22/2015 2:03 PM
tighten each side a little at a time alternating sides. my modded fbm does the same thing
1/22/2015 2:09 PM
I've tried that
1/22/2015 2:28 PM
Mine works just fine
Testimony and apologies
instagram
old edit
1/22/2015 2:47 PM
Show pic of it on your bike
1/22/2015 3:01 PM
you should put the spacer on the inside of your peg bro. and make sure you have enough spacers inside the drop out, there shouldnt be any visible gap between the inside of the dropout and the lock nut on the hub. If there is that could be causing it.
NEW Bike check
Raw Clips Edit
1/22/2015 3:05 PM
Makes some sense ima try your idea
1/22/2015 5:04 PM
Did it have this problem before you installed the guard?
Also check to see if the guard is touching any of the frame's welds, that could cause it to sit uneven in the dropouts and shift easier.
Also check if your dropouts are bent at all, that could be contributing to it too
1/23/2015 5:36 AM
instagram
old edit
1/23/2015 5:55 AM
Is your wheel lined up
1/23/2015 12:52 PM
For the most part yes and no due to my frame not being welded together correctly back there (thanks solid) but im sure it would sit it there wih no issues if i have a frame that was made right
I also have the infinity guard on the other side
definitely recommend it if you go 4 pegs
instagram
old edit
1/23/2015 12:53 PM
The drive side guard is pretty huge make sure its not resting on the welds of your frame thats the only down side of this hub guard
instagram
old edit
