Dropouts help
4/15/2014 5:58 AM
I used to grind a bit and I have a Wethepeople Addict 2009 bike. The thing is that, when I tried to take the back wheel off to put a hubguard, the wheel didn't came out because grinding I bent the dropouts. What can I do to solve this?
4/15/2014 6:39 AM
Carefully try to spread the dropout a little.
Then, don't land on the dropouts if you can avoid it.
4/15/2014 7:26 AM
You can hammer it back though I wouldn't suggest it. I would just file down the inside of the dropout where its bent until it works like normal. Or if its severe, and you know what youre doing, use a saw.
Or try to man handle your wheel out.
4/15/2014 7:27 AM
file the dropouts down a little bit, had the same problem
4/15/2014 7:51 AM
Get a big ring spanner onto your drop out and pry the end down to get your wheel out
4/15/2014 8:46 AM
Be careful. A guy I know did this and snapped his dropout off.
4/15/2014 10:38 AM
Sledgehammer to the rear end ..... Something will come of it
4/15/2014 10:41 AM
Edited Date/Time: 4/15/2014 10:43 AM
Gotta be careful a buddy of mines cracked his dropout doing this, but then again he was being retarded and tried bending it so it would be straight again
Murica bike check
4/15/2014 3:41 PM
Be patient and carefull with everything, you can fuck them up
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
