Eastern Axis?
10/10/2009 11:18 AM
Is this bike good also whats the deal with lightning rod tubing
# Frame: Eastern Full-4130 Chromoly Frame with Proprietary Lightning Rod Tubing, Replaceable Brake Mounts, Tapered Butted Chain Stays, Seat-Tube Cut-outs, Eastern Heat Treated Dropouts, and Integrated "Grim Reaper" Seatpost Clamp
# Forks: Eastern Full 4130 Chromoly with Tapered Legs, and New Hangfree Dropout Design
# Cranks: 48 Splined with Eastern Stealth Arms, 3PC Tubular Chromoly
# Bottom bracket: Eastern Sealed Bearing Mid-BB
# Pedals: Eastern Plastics
# Sprocket: Original Eastern 25T Medusa Lite Alloy Sprocket
# Freewheel: 9T One Piece Driver w/ 6 Pawls and 15 Degree Engagement, Sealed Bearings
# Chain: KMC Z510HX
# Rear Brake: Tektro U-Brake
# Front Brake: Chang Star RX 402 HA
# Levers: Tektro Designed For U-Brakes
# Bars: Eastern Full Chromoly 8.25x28" w/ 1.6mm Wall Thickness
# Stem: Eastern Strangler Stem w/ Interal Wedge Clamping System and Excess Material Removed for Weight Savings 55mm Reach
# Headset: Sealed Bearing 45/45 Internal
# Grips: Eastern Coral Grip
# Rear Hub: Eastern Original LB-9-2 Bi-Directional Hub 36H
# Front Hub: Eastern Forged Alloy Shell, 3/8" Chromoly Axle, Sealed Bearings 36H
# Rims: Kinlin Double Wall Alloy, BM25, 36 Hole
# Front Tyre: Eastern CURB Monkey OEM Version, 20 x 2.3
# Rear Tyre: Eastern CURB Monkey OEM Version, 20 x 2.4
# Seat: Pinner Pivotal
# Seatpost: Alloy Pivotal
# Seatclamp: Eastern Original Design Integrated Grim Reaper Style
# Rotor: No
# Pegs: 2 Eastern Bird Pegs
# Top Tube Size: 21”
10/10/2009 11:48 AM
It's a high-end Eastern, so It's pretty good. But It's a 21" TT, so depending on how tall you are...
MOTW- 6/21/10- 6/27/10
Refs- Hyphy
Facebook
10/10/2009 11:49 AM
well on dans comp it says 20.5 so im guessing yu can choose the size?
10/10/2009 11:54 AM
If Dan's says it 20.5, that what it is.
Refs- Hyphy
Facebook
10/10/2009 12:51 PM
ok thanks i dont know why i was confused idk thanks though
10/10/2009 2:26 PM
seams mad nice get it
don't put your finger anywhere you wouldn't put your dick
cell# 518 682. 718.0.(only for parts)
refs
i ride fly, devyn, hattrckhcky, spikez5, blackout2010, 3514eclat, mikelee, brecher, TCbmx
10/26/2009 3:28 PM
Actually I deal with Eastern and the Axis is a 21" top tube not 20.5. Dans Comp is wrong with a lot of measurements and weights. I wouldn't trust what they print.
John
10/26/2009 4:18 PM
The lightning rod tubing is thicker where you could dent it, and thinner where you are less likely to dent it. (thicker on bottom of down tube, thinner on top of down tube)
23.94 lbs, and their site doesn't specify tt length.
4/4/2011 7:17 PM
im in need or rear brake mount studs so i can put my brake setup on since the studs are smaller than the usual size its making it hard for me to fin eastern aparently didnt have any in stock it wat ive been told
4/4/2011 7:18 PM
4/4/2011 7:37 PM
Hey.....1.5yrs later!
Legit
Oscar5788,Scramhype,SuperstarDK,Howlerfbm,AlexDanielP,KilledGlamour,notorious NIG,KYMIKE
