The top one is a Haro hypno axle it has been cut and the middle one is a eastern axle and the bottom one is a colony axle of a clone hub what is the difference between them do you guys think they would work on Haro rear hub
ride or die
ride or die
Check the specs on each, if they seem to be exactly the same then they are fine, they certainly look alike.
make sure the length is the same and ur goosd
Save a tree
Can you measure your axle quick? I have an Eastern axle laying around here I can measure for you if you get me your measurements.
Measure the middle piece's length, like from the flange thingy to the other flange thingy
also measure the silver area of where the driver goes (the bigger part)
get me both those lengths and I'll see
sundaybmxRR wrote:Can you measure your axle quick? I have an Eastern axle laying around here I can measure for you if you get me your ...more
flange to flange is 1.62 inches or 4.13cm
big sliver is 1.33 inches or 3.4cm
little silver is .5cm
ride or die
Easter won't fit, the center part is longer. Don't know about the Colony
sundaybmxRR wrote:Easter won't fit, the center part is longer. Don't know about the Colony
how much longer
ride or die
