Ezra wheel with peg?
5/10/2013 12:26 PM
I have the Ezra Opus rear wheel and i want to know what size peg i should use. The wheel has 3/8th'' bolts in to a 14mm female axle.
IG @curtis_cantbmxwell
@kirolling
5/10/2013 12:32 PM
Make sure you have the chromoly axle cuz from what heard the alloy ones are not suitable for grinding, if you have ne trouble getting hold of a replacement chromoly axle from vien I know that the eastern venus axle replacements are exactly the same if you need to swap em out, as for pegs I assume you will need some with the same size holes as the bolt, other than that I pretty sure most pegs come with an adapter to fit either size.
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
5/10/2013 12:40 PM
Yeah the wheel came with all 3 axles.
@kirolling
5/10/2013 12:46 PM
3/8ths bolts need 3/8ths pegs smile
5/10/2013 1:11 PM
Soulrebelrastaman wrote:
Make sure you have the chromoly axle cuz from what heard the alloy ones are not suitable for grinding, if you have ne trouble ...more
As it's Female, the Axle material doesn't really matter for grinding as it doesn't hold the pegs weight.
5/10/2013 1:28 PM
Ok. Does anyone know if there are any pegs that are less expensive but still good for grind besides the ezra grind pegs?
@kirolling
5/10/2013 2:07 PM
Amber pegs?
Anything in 3/8 will work
Instagram
5/10/2013 7:28 PM
You need 3/8, my friend had those wheels. Just get the Ezras, they're good, and they last.
Phone - 704 - 797 - 6844
5/10/2013 10:24 PM
I have those wheels off a complete, you need female 3/8th's pegs to work. Axle is pretty tough just make sure you tighten the bolts down if your pegs dont have anti rotation pins or your chain will always be loose.
