FIT BOTOM BRACKET HELP
6/21/2008 6:17 AM
i cant get my spindle in my fit pro trail. anyone ever had this problem. i need help
6/21/2008 6:34 AM
I know that fit had a 20 mm spindle on their completes for a while, as my buddy had to basically grind his spindle to get it into some different 19mm bearings for a diff frame...he was kinda pissed...
6/21/2008 11:43 AM
bearings probally aren't pressed in straight
you can't learn to flow by reading books
6/21/2008 2:48 PM
Make sure your bearing diameter will work with your spindle diameter. If they are the same, make sure they are seated properly in the frame or cups (whatever it has)
6/21/2008 2:50 PM
if you can get the spindle through the first bearing then the size should be ok, its either your bearings are not pressed in right or the spacer is crooked or something
My refs ?... Nigga just ask about me
