Female axle on stock male hub
9/26/2013 9:20 PM
I've got a blank front wheel and I was wondering if there are any female axles that fit in stock male hubs?
9/26/2013 9:54 PM
Fuck yea, do it!
9/27/2013 6:23 AM
Nope. You can make a female out of a hollow 14mm axle, but not 3/8s.
9/27/2013 2:17 PM
Edited Date/Time: 9/27/2013 2:18 PM
Drill out the hub with a lathe so you can run 6902 sealed bearings in it (6802 if its a low flange hub. but it won't be as strong as the otherbut it'll still be more than strong enough ) and a 15mm primo n4fl axle. Then get some washers or hub guards to work as cones then get some gsport bolts and it'll be sick
9/27/2013 2:21 PM
sunny.noble wrote:
Drill out the hub with a lathe so you can run 6902 sealed bearings in it (6802 if its a low flange hub. but it won't be as ...more
It's like a different language.. I don't get hubs >.
ı̸̸̸̸̸̸̸̸̸̸̸̸̸̸̸̸̨
9/28/2013 3:28 AM
Edited Date/Time: 9/28/2013 3:30 AM
Thanks for that. I'm pretty sure I know someone with a lathe so when I can I'll try that.
