Which is a better choice on a freecoaster?
Hmmhm I'd go male if you grind. Of course people will comment that female is better but thats opinions clashing.
If you are heavy on your coaster, but barely grind get that female because it is less likely to have your axle bend, which can be a problem with male coasters. But if you arent heavy but grind, get the Male Coaster, the female bolts are weak.
If they make a 17mm center axle with 14mm female bolts a true female coaster, that would be amazing.
Brayden_Buckingham wrote:Hmmhm I'd go male if you grind. Of course people will comment that female is better but thats opinions clashing.
Male 14mm in the back > female 3/8", but female 14mm > male 14mm
I would personally go male just cause I like the look of them in the back.
