Fit . Headset problem?
6/3/2013 7:14 AM
I have the fit bf3, and it feels like my headset is loose and has a little notch in it when you push forward on the bars. the bike is 3 weeks old and everything is tightened down and doesnt seem loose but there is that little notch when riding or turning the bars..any ideas?
6/3/2013 7:16 AM
loosen the side bolts on the stem , and tighten the headset
6/3/2013 7:29 AM
Take it apart and re install it.
6/3/2013 7:29 AM
This. You need to do up your compression bolt a little more. Pretty common with new bikes things come loose after a little use. Undo the side bolts at the back of your stem, tighten your compression bolt (The Bolt on the top of the stem) Wiggle your forks & bars back n forth till it doesn't wobble anymore, tighten the bolts at the back of your stem. Yo are done & ready to ride.
6/3/2013 9:00 AM
Thanks for the help!
