I was looking into getting a 20.25 TT bmx, I’m not sure what the best one is with full Chromoly and sealed bearing for under $600 CAD.... I was looking at both the Fit Mac Man and Fit Nordstrom, which one is better?
Please provide me with a better bike in the same size if possible, thank you, enjoy your day
MAC-MAN:
COLOR: Pac Black.
FRAME: 100% CrMo., 20.25″ TT.
BARS: 2 pc. 8.7″ x 29″
FORK: 25mm Offset.
STEM: FIT Forged Top Load.
GRIPS: FIT Longtech Flangeless.
SEAT: FIT Barstool Pivotal.
CRANKS: FIT Indented CrMo 165mm.
SPROCKET: FIT Key 25T.
PEDALS: FIT Mac PC.
WHEELS: Sealed / FIT S1W (front) / Cassette 14mm Axle / FIT S1W (rear).
TIRES: 2.4 FIT OEM.
WEIGHT: 25.5 LBS / 11.57 KG
GEOMETRY: Street.
Top tube length: 20.25″
Rear end length: 13.11″
Head tube angle: 75.5°
Seat tube angle: 71°
BB height: 11.8″
Standover: 8.8″
Head tube: Integrated
Bottom Bracket: Mid
Dropouts: 14mm
Brake mounts: U-brake
Seat clamp: 28.6mm
Seat post size: 25.4mm
Nordstrom
Size: TT: 20.25"; CS: 13.11"; HT: 75.5°; ST: 71°; SO: 8.8"
Frame: 4130 chromoly
Forks: 4130 chromoly, tapered legs, 25mm offset
Bars: 2-piece chromoly, 29" x 9.25"
Stem: Fit forged alloy top load
Headset: Integrated sealed
Brake Levers: Alloy 2-finger
Brakes: Removeable mounts, 990 U-Brake
Gearing: 25x9T
Cranks: 8-spline, 3-piece tubular (170mm)
Bottom Bracket: Sealed Mid
Pedals: Odyssey plastic
Front Hub: Alloy sealed, low flange, 10mm axle
Rear Hub: Alloy sealed, 9T cassette hub, 14mm axle
Sprocket: Fit chromoly Series One 25T
Rims: Revenge S1W single wall, 36H
Tyres: Fit T/A 20"x2.3"
Seat: Fit Barstool Pivotal
Pegs: Steel pegs included
Weight: 26.1lbs/11.83kg
