Fit faf nightvision 2.25 rear on a premium deathtrap
9/28/2013 9:04 AM
Hi, im looking at buying a pair of fit fat nightvision tyres in 2.25.
I am running a premium deathtrap frame, will a 2.25 fit in the rear with a brake?
Cheers
9/28/2013 9:33 AM
What tires are you running right now? Which brakes?
9/28/2013 9:38 AM
I have the stock premiums that came with the bike, i think the rear might be 1.9 and i replaced the rear brake with a blank u brake a while ago.
9/28/2013 10:30 AM
The 2.25 should be fine. But you may not be able to run your wheel slammed.
9/28/2013 10:34 AM
Are you sure? I have read that the fit faf 2.25 has a bigger tread pattern and when inflated is slightly larger than a 2.3 tyre
Thanks for your help
9/28/2013 10:52 AM
You should be good, yes the 2.25s are bigger and better than the 2.3s but they should still fit I used to run them in my stock Fit frame and they were fine and I have a birdcage rim in the back which is a little wider than some rims so you should be good.
My Fit
9/28/2013 11:11 AM
Great, thanks
