Fork/Headset Noise
9/2/2013 5:31 PM
today i noticed a problem , when i turn my bars like 100 degrees on a quarter , they make a metal clicky noise. like "CLICK CLICK" and than it goes normal. sometimes it hapens other not. anything is loose , bunny hoping , grinding , all ok , but when i turn more than 90º it makes that noise.
9/2/2013 5:39 PM
Sounds like eithet dirt or your bearing is starting to dislodge
Put in work.
Put in work.
Put in work.
Flacko put 'em in the dirt.
9/2/2013 5:46 PM
oh ,i was worried about buying a new fork. i'l try to clean it tomorrow , if that doesn't fix , ill need to get a new headset? can't be like a ovalized steerer tube or stem?
9/2/2013 5:51 PM
I'm 99% sure it's your headset
Put in work.
Put in work.
Put in work.
9/2/2013 6:00 PM
fuck :/
i'll try to make it come back to life ahah
9/2/2013 6:23 PM
do you have a gyro?
MIDWEST MOTHER FUCKER
9/2/2013 6:55 PM
No , but it couldn't be either i think. i feel that shit , is someething massive a big loud click
9/2/2013 7:10 PM
its your head set, do you have a slandered or integrated
9/2/2013 7:18 PM
integrated.
9/2/2013 7:56 PM
Your bearing might be fucked
Put in work.
Put in work.
Put in work.
9/3/2013 3:35 AM
mine has made that noise forever, and everything got replaced, forks, bearings, stem and frrame. and i still get that sounds:L although its my bearings. I got a new headset and within like a day the bearings got fcked coz i was borrowing some forks (mine were bent) and it got jammed on the race at the bottom....
NEW Bike check
Raw Clips Edit
9/3/2013 5:33 AM
ill try to clean everything. i'll tell you something later.
9/3/2013 6:04 AM
do you run a gyro? if so that is probably it.. if not then its your headset. but if its ur gyro then the actual gyro is sitting sideways and you just have to adjust the (knarps?) or whatever they are until it levels out...
Deviant BMX store
9/3/2013 6:34 AM
here is a vid. i'll try to fix it now :/
Onlythe first 2 noises are the headset , the others are just me hiting the camera.
http://img38.imageshack.us/img38/4781/2orlqhpnfoxaywjjistfet.mp4
9/3/2013 5:44 PM
...more
it should be fine
9/3/2013 6:11 PM
didn't had time to clean today :/
hod do you say " it should be fine"? no need to replace?
9/3/2013 6:45 PM
no you dont need to replace but if it actually becomes a problem like your headset freezes up or something like that you will.
