Fork Pre Load Bolts
12/9/2018 8:24 PM
Probably a stupid question but can you swap Fork Pre Load Bolts?
I wanted to use the S&M Compression Bolt on my Odyssey R25 forks on my new build.
This is my first pair of forks with an actual Compression Bolt and not the old Star nut set up and I'm not sure if they're interchangeable and can't find the size on the odyssey bolt.
12/9/2018 8:58 PM
You can swap some fork bolts as long as the sizes are the same, but in this case you cannot. S&M uses a size H10 bolt, Odyssey uses H24
12/10/2018 2:14 AM
The older s&m forks use m10, the newer ones are m24
http://www.empirebmx.com/sm-fork-compression-bolt
