Nwewinit wrote:
The reason they're flat on the bottom with a little curve is because it is a punch pressed part. It's a 45 degree angle top ...more
Nwewinit wrote:
The reason they're flat on the bottom with a little curve is because it is a punch pressed part. It's a 45 degree angle top and bottom to match the campy bearing that it was punched for not the fork. It has always been punched at a 45 degree angle unless you have one of those goofy 45/36 bearing headsets...
Older heasets didn't even need an angled race on the forks because they didn't use angled bearings... I'd assume you'd know atleast that before you said it was wrong.
Standard headsets used caged bearing pressed in from the the forks and stem, the bearing races were called " bearing cups" (essentially a sealed bearing you can take apart) the bearing wasn't actually in cintact with the fork at all. Just the back of the bearing cage the bearings rolled freely against the bearing cups. The only thing that was down there WAS a flat tiny washer to keep grease in and dirt out.
And an internal headset was just a terrible fucking idea.
I'm not exactly sure how a Hi-tensile steel fork race would shatter, but wierd shit happens to bikes so, sure.
I think we have a misunderstanding because explaining what I'm trying to specify over the internet is hard.
Both forks made with standard headsets and forks made for integrated headsets (Ones without integrated races) have flat spots where the lower bearing race sits, and are just slightly tapered right above that for a snug fit, or have an edge that the race slides over and fits snugly with. You can see what I'm talking about here
The bearing races that are used have a curved part on top where the bearing will sit, but on the bottom of them they usually have a curved part there too where they rest at the bottom of the steerer. You can see the curved part in the above photo too if you zoom in. That's where you & I are currently confused.
The lower bearing race YOU have fits over the integrated race perfectly and is the same angle as it, so it fits fine with no problems. But I remember when I first got forks with an integrated race, I tried putting the lower bearing race from my Colony integrated headset on it just to see if it would even fit out of curiosity, and it did not fit on the race because the angle was very different (Yes, it was 45°x45°)
That's why I initially said it was wrong to do that. Maybe Colony just didn't use the same lower race as everyone else or something, but I know for sure that one didn't fit on there right which is why I always figured it was wrong since then. I just think, and still do, it looks uglier that way. Like something's installed wrong or something. If it works for you then good. I'll see if I can find that specific bearing race and take photos of it and photos of it on my integrated fork race to show you too, assuming I even have it anywhere anymore. I have no clue where it would even be as this was over 6 years ago.
