Frame chain stay length
1/31/2014 8:21 PM
If the geo on frame says 20.5 - 21 TT and a 13.4 - 14 CS, then if I get a 20.5 TT will the chain stay be longer like 14 or if i want a 14 CS I should get a bigger sized TT
My AWESOME Bike Check!!!
"I ride a little kid’s bike every day and would not want to do anything else with my time" -Aaron Ross
"keep your feet on the ground but keep reaching for the stars” -Brian Kachinsky
1/31/2014 8:22 PM
Question or statement?
1/31/2014 8:23 PM
13.4-14 is the size of the cs depending on where the wheel sits in the dropout. If its closer to the frame then it will be 13.4 if its pulled back it will be closer to 14 depending on gear ratio.
2/1/2014 6:17 AM
20.5 with a 14" back end? What type of riding do you do? How tall / old are you? If you want a back end that long you should probably look for another frame as its not likely that you will run your wheel all the way at the end of your chainstays.
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
2/1/2014 6:19 AM
13.4-14 is the lengh of a the chainstay when the wheel is slammed and 14´´ is the furthes you can go
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
2/1/2014 7:07 AM
13.4 = the very front of the drop out (slammed)
14 = the very back of the dropout (as far back as your wheel can go without hanging out)
So 13.4 is the shortest you can make it, and 14 is the longest you can make it.
So they all come with the same CS length, it just depends on where you put your wheel to make it feel longer or shorter
2/7/2014 2:45 PM
transition_chris wrote:
20.5 with a 14" back end? What type of riding do you do? How tall / old are you? If you want a back end that long you should ...more
haha it was just a random example. all types. 5,1". 12
