Freecoaster DS hubguard problem!!
8/1/2013 1:26 PM
hey everyone! Got a problem. I run 4 pegs and a freecoaster and for some reason whenever I put a drive side hubguard on my hub it makes a weird clicking/popping/grinding sound when I pedal hard. Do you know what causes this? I run a non-drive side guard and it doesn't give me any trouble but when I put a hubguard on the drive side it starts making noises. Any help would be great! Thanks
Stay fit, ride a Fit, crash and have a fit.
8/1/2013 1:41 PM
sounds likes your chain is rubbing your guard
Refs:
Traded: tomdon
n-dür on facebook
8/1/2013 1:44 PM
This seems right.. What size Driver do you have? What Chain are you running? aaaaand What DSG do you have?
8/1/2013 1:49 PM
im assuming he has a plastic primo dsg.
Refs:
Traded: tomdon
n-dür on facebook
8/1/2013 1:59 PM
Not necessarily. My rush v2 driver & kmc 510 don't rub my pc dsg
8/1/2013 3:27 PM
I've got a rush v2 and a kmc 510 and a primo dsg.
8/1/2013 3:29 PM
Should I buy a new guard or what could I do to this one to fix it?
8/1/2013 3:29 PM
Its a 9t Driver right? I don't think they did any bigger? However if its an 11t like some KHE Clones did offer then the DSG wont fit over it 10t is the MAX.
8/1/2013 3:31 PM
That is my exact setup lol. So how is it your chain rubs and mine doesnt?
8/1/2013 3:40 PM
make sure the guard is centered on the chain so it has an even amount of room around it... andif it still rubs then use a file and file the edges down... also if you have like a 28tooth sprocket or bigger then it wont fit so you need to shave it even more.
Deviant BMX store
8/1/2013 3:45 PM
DeviantBMX123 wrote:
make sure the guard is centered on the chain so it has an even amount of room around it... andif it still rubs then use a file ...more
Well no he could be running 28/9 gearing or even 30/9 gearing. It doesn't matter what Sprocket size he has its the DRIVER size that makes the difference. If he has anything bigger than 10t in the back the guard will not work.
8/1/2013 7:42 PM
Daily grind would work great
Albes Is Rad!!!
YouTube
Instagram
Blood Life
8/1/2013 7:51 PM
Topsey wrote:
Well no he could be running 28/9 gearing or even 30/9 gearing. It doesn't matter what Sprocket size he has its the DRIVER size ...more
if you have something biggger than 25 then the chain comes out at more of an angle.. so if you have anything over 25t then it can hit and you have to shave the edges down to give it more clearance... i know cuz i was running a 9t driver and it didnt fit because of the 28t sprocket... now like your saying if he has 10t in the back then the guard wont work at all... im saying that he might have to mod it a little for the bigger sprocket...
Deviant BMX store
8/1/2013 8:37 PM
The primo one is retarded I have the aluminum one and even with 25/9 it hits, the daily grind dsg fuck anything else
Albes Is Rad!!!
YouTube
Instagram
Blood Life
8/1/2013 8:45 PM
Yeah the metal primo dsg is hard as hell to adjust right & a mm or 2 off & it rubs.
Instagram
8/1/2013 8:45 PM
yeeeahh haha i bought one and had to mod it so much to fit 28 9 i ended up just throwing it away... is the daily grind universal?
Deviant BMX store
8/2/2013 5:45 AM
I'm getting a fair amount of grinding with my primo dsg on a 30t to a 9t ratchet. I really want to try the daily dsg
8/2/2013 5:53 AM
i have a khe astern. eclat diesel -- basically a 710. and plastic dsg. i let it rub for months before i modded it... now its not even close to rubbing.. and i currently ride 28/9
Refs:
Traded: tomdon
n-dür on facebook
8/2/2013 6:54 AM
Edited Date/Time: 8/2/2013 6:54 AM
My PC dsg works fine on 28/9 with no mods
8/2/2013 7:00 AM
mine is crushed a bit where it rests on the locknut
Refs:
Traded: tomdon
n-dür on facebook
8/2/2013 7:46 AM
yeeeahh haha i bought one and had to mod it so much to fit 28 9 i ended up just throwing it away... is the daily grind ...more
yea it can be used on almost any hub but you may have to mod the base area because it is hub so if you run a slammed rear it might rest on the welds
Albes Is Rad!!!
YouTube
Instagram
Blood Life
8/2/2013 7:57 AM
yea it can be used on almost any hub but you may have to mod the base area because it is hub so if you run a slammed rear it ...more
so what do you mean mod the base? ill definitly look into it... it seems way better than the primo.
Deviant BMX store
