Freecoaster changes slack?help
10/16/2017 3:17 PM
My freecoaster recently started to slip and change slack. Sometimes its almost 3 full cranks sometimes its stock slack and sometimes its almost instant. I dont know if the problem is in spring or clutch because my spring balls are almost new.
Any suggestions or tips .Has something like that has happened to you. Also i regrease my hub every ~2 months.
10/16/2017 4:01 PM
Watch_Doge wrote:
My freecoaster recently started to slip and change slack. Sometimes its almost 3 full cranks sometimes its stock slack and ...more
Check if there's a groove worn on the inside of the clutch. If there is, you need to replace it. Otherwise, it's the ball bearings.
10/16/2017 8:22 PM
Silly question - what type of freecoaster? Mine are all axle, driver, clutch, spacers, sealed bearings, and lock nuts.
10/16/2017 9:09 PM
Same type as yours unless you have the odyssey clutch, the ball bearings mentioned above are the spring-loaded ones that give the clutch some resistance in the normal KHE type coasters.
