Freecoaster help
9/4/2016 6:38 AM
I have a Cult match v2 freecoaster that i bought around 2 weeks ago, im having a little ghost pedal issue and the freecoaster feeling slugish after i regreased it. When i tighten the ds conenut the wheel spins bad. Hope someone can help me out, Thanks!
9/4/2016 6:41 AM
sigurdbmx wrote:
I have a Cult match v2 freecoaster that i bought around 2 weeks ago, im having a little ghost pedal issue and the freecoaster ...more
How tight are you tightening the cone nuts? Should be a hair tighter than finger tight (like 1/16 turn). Then with the compression from the axle nuts it's perfect
Also how much grease did u put in there?
Dax in NYC
MD & Flatland rider
9/4/2016 6:54 AM
i tighten it fingertight ( i never use tools to tighten a conenut on any hub) i used a decent amount of grease, it may be the grease being to thick, im not sure
