Front hub issue [FIXED]
12/21/2014 6:28 AM
I have a BSD front street hub, the bearings haven't been greased in a year, so I took off the cones and now it's just the axle, it can move left to right, I greased them up (didn't take them out - just the outside) I put the right cone on first and pressed it in, I think I tightened it a bit now the bearings on the left are sticking out a bit? How do I fix it
Bearings aren't sticking out : Photo
Bearings sticking out : Photo
12/21/2014 6:32 AM
well, how much grease did ya use? grease does have a thickness, its gotta take up some room....
try taking it out and wiping a little of the grease out, and see if it fits better, if its not good after that, it might be time to head up to your lbs
"The D.O.P.S. System"
DK, Odyssey, Profile, Shadow.
check out my bike check
@ethanbrackett
12/21/2014 6:36 AM
try taking it out and wiping ...more
tiny bit of WD40 on a cotton swab then rubbed it around the outside of the hub, only using WD40 until I can find some 3 in 1 grease
12/21/2014 6:40 AM
never heard of 3in1 grease, heard of 3-1 oil....
Finish line grease works hell any kinda grease will really work... best off with a water resistant grease. cheapest thing at a hardware store will even work. course the nicer and more expensive the grease the better, but hey its freakin grease.
if thats the case maybe a cone washer isnt turned the right way or is contacting the hub off slightly, just play around with it, it'll get their eventually.
@ethanbrackett
12/21/2014 6:41 AM
Finish line grease works hell any kinda grease will really work... best off ...more
I meant 3 in 1 oil, not 3 in 1 grease tongue
I'll mess around with the hub and see what I can do
12/21/2014 7:09 AM
So I just hammered the axle out and got both of the bearings out, now it's just an empt hub shell, where do I go from here?
12/21/2014 7:16 AM
@ethanbrackett
12/21/2014 7:37 AM
kaneBMX wrote:
tiny bit of WD40 on a cotton swab then rubbed it around the outside of the hub, only using WD40 until I can find some 3 in 1 ...more
Dude don't ever used wd-40 it's a degreaser. It mess up everything unles it's old and you need to get something out.
Then shall the dust return to the earth as it was: and the spirit shall return unto God who gave it. (Ecclesiastes 12:7 KJV)
Sold to: storeboughtchild,Maximusbikes,cro tec,Showtime402,Kevinbrock338,dktechethan,Robinson79
Traded: livefreeordie2332(x2), Aebasher.
TXT Me (480)340-7551
12/21/2014 7:46 AM
This
WD-40 is a degreaser and will destroy your bearings
Testimony and apologies
instagram
old edit
12/21/2014 7:57 AM
WD-40 is an OIL and acceptable on a chain, but any bearings need GREASE, and WD-40 will remove it all
12/21/2014 8:25 AM
Idiot just take it out and make sure nothing is blocking it then tighten your axle nut all the way
13 years old
12/21/2014 8:49 AM
Fixed it :
Removed all the WD40
Hammered the bearings onto the axle equally : problem solved
