Front hub problem
7/22/2017 4:41 PM
Hey guys,
my front hub is having some problems sad It doesn't spin smoothly and stops immediatly like 3 seconds after I make it spin with my hand. When I took it off the fork I noticed that it makes some little sketchy noice when spinning..
It's a new default sealed hub that came with a complete bike..
Thank you guys!
7/22/2017 4:46 PM
That's why you should never buy a complete bike ...
7/22/2017 4:54 PM
shagged or collapsed bearing(s) probably is most likely culprit
7/22/2017 6:11 PM
bearings you can probably have them replaced for like 30 bucks at lbs if they got em
7/22/2017 11:38 PM
Does it spin freely when it's not in the forks? If it has a threaded cone, try loosening it off a touch. If it has a bush instead, one of them may be touching the bearing too much. Profile make really thin spacers that can cure that
7/23/2017 5:46 PM
Shit I've been riding 20 plus years and I'm on a complete now and it came with Cinema VX2 wheels. Your statement is not true
7/23/2017 6:43 PM
I agree.
Take the wheel off the bike and inspect your hub. I mean pull it apart and rebuild it. Don't forget grease. If you notice the bearing seal is pressed in or they feel kinda gritty when you spin them, head to a machine shop. They will probably have the bearings that fit perfectly and cost about $10.00.
You can always carefully pull the cover of the bearings off. Then clean them out and regrease them. I highly recommend marine grease, blue or green. It is super smooth and lasts longer than everything else I have used in 30+ years riding
