2014 Terrible One Barcode Ovalized Headtube
4/13/2014 1:25 PM
Edited Date/Time: 4/13/2014 2:47 PM
So, as many of you guys know, I'm working on a new build. Started to build it up and I realized I have wobble up front. Can't figure it out. Setup is...
T1 Barcode frame
Odyssey R32 forks (Steerer tube is cut, but it is straight and smooth)
Odyssey Lincoln stem
FSA Impact headset bearings
Zodiac dust cap
Tree compression cap
There is 4mm of room between the top of the steerer and the top of the stem. Everything is installed properly. I used all the shims that come with the dust cap and there is about 1mm of space between the headtube and dust cap.
I did notice that the dust cap is closer to coming in contact with the headtube at the front, and further at the rear. I feel like this has something to do with it. Also, when I turn the bars sideways, there is no wobble that way. Just front to back wobble.
Everything is BRAND new and I inspected everything and it seems to be fine. I've taken everything apart 5 times now, switching bearings and everything. Nothing fixes it. And yes, the wedges in the stem are tightened so it's not that. Tightened the compression cap to the point where the headset doesn't spin freely. Still wobbled. Can't figure it out and it's pissing me off.
OVALIZED HEADTUBE FTW?
YOU AVIN A LAUGH M8?
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
The Trailest Bike On Vital
4/13/2014 1:37 PM
Ovalised headtube maybe? Unlikely I know but even the best manufacturers make mistakes.
4/13/2014 1:39 PM
I think it's either that or a problem with the headset bearings or upper race. The angle the dust cap is at is just weird. I have a pic of it before I added all the shims, so the dust cap is lower than what it is now. Hard to see but...
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 1:42 PM
Think you might be right. Took it apart, turned my bars 90 degrees from my forks, and the wobble is gone. I'm a bit fucked if it is ovalized.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 1:43 PM
Fuck. Um. I'd suggest putting more spacers on but you probaly know what you're doing. Maybe rearrange them? How much are you using?
4/13/2014 1:45 PM
Edited Date/Time: 4/13/2014 1:45 PM
Brayden_Buckingham wrote:
Fuck. Um. I'd suggest putting more spacers on but you probaly know what you're doing. Maybe rearrange them? How much are you ...more
No spacers. Just the dust cap. There is plenty of room between the top of the steerer and the top of the stem. The current dust cap is 5mm, but I tried with an 8mm dust cap, bringing the space between the top of the steerer tube and the top of the stem to 7mm and it still wobbled. That's to the point where the Lincoln won't install properly. Also plenty of room between the headtube and dust cap.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 1:49 PM
Just throwing this out there, but you didn't install the bottom headset race, did you? The R32 has an integrated one.
Instagram @tkeck74
4/13/2014 1:50 PM
Edited Date/Time: 4/13/2014 1:56 PM
Nope, no lower race. I might try to get a new upper race and bearings. If that doesn't fix it I'll hit up T1. Don't know what to do if it does have an ovalized headtube.
So I checked both the FSA and Zodiac caps. Neither match the shape of the headtube. The front of the headtube sticks out past both caps... Fuck.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 2:02 PM
Well... shit...
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 2:14 PM
That sucks dude
4/13/2014 2:16 PM
BMXSkater wrote:
That sucks dude
Yeah... it sucks lol. I know Joe Rich will be cool about it, but I'm not happy about having to get my Thunderbolts out of there because they were a bitch to get in lol.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 3:12 PM
I guess you just got a "terrible one"
That sucks man.
IG @curtis_cantbmxwell
@kirolling
4/13/2014 3:24 PM
That sucks man.
Did you just........
4/13/2014 3:27 PM
That sucks man.
Yes, yes i did.
@kirolling
4/13/2014 4:15 PM
Edited Date/Time: 4/13/2014 4:24 PM
Try posting photos of JUST the bearings in the head tube. Take the forks out.
This way you can look and see if the bearings are incoorectly shaped for the HT or if it is the HT.
Then you can wiggle the bearings and see if there is play there.
Also look at your front wheel for the wiggle you are talking about. I have had a wheel bearing go and give a feeling like the headset was toast.
4/13/2014 4:20 PM
This way you can look and see if the bearings ...more
Switched the bearings around and they're the same... Definitely the headtube.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 4:58 PM
Is the upper bearing race the one that came with the bearings? I've had headset troubles like this before & it was due to the upper bearing race being different. I know it was that because I tried one, it wobbled, tried another different style of upper races, and it didn't wobble.
4/13/2014 5:00 PM
sundaybmxRR wrote:
Is the upper bearing race the one that came with the bearings? I've had headset troubles like this before & it was due to ...more
It's the one that came with the headset. It's definitely an ovalized headtube. The bearing moves inside the cups. Tried both bearings and neither of them fit.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 5:12 PM
Sucks for you haha!!!!
Just kidding i'd be pissed if this happened to me. Hope they give you a new one. Better or you can go all hook on em'
4/13/2014 5:39 PM
That sucks man.
Oh my god. I cant even.....
I am SO DONE!
4/13/2014 6:07 PM
I am SO DONE!
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 6:13 PM
Dust cap. The dustcap deformed. Happened to me too. Try a different dust cap. Thatd solve it.
4/13/2014 6:14 PM
Edited Date/Time: 4/13/2014 6:15 PM
Not deformed. It's brand new, plus it's stronger than pretty much any other dust cap. You can clearly see it's the headtube. Plus, like I've said before, the problem remains with multiple dust caps.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 6:24 PM
Xxohioanxx wrote:
Not deformed. It's brand new, plus it's stronger than pretty much any other dust cap. You can clearly see it's the headtube. ...more
Ahh damn, sorry to hear that. looks like youll get a new one. hahaa
4/13/2014 7:15 PM
I am SO DONE!
Xxohioanxx wrote: Photo
Bang your dead
@kirolling
4/13/2014 10:26 PM
blaaaaaaaaa wrote:
Bang your dead
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
4/13/2014 10:49 PM
Try putting a slim spacer under and a thicker one on top of the stem to see if that helps. I had somewhat of a similar problem to you with my lincoln and I added a spacer on the bottom to stop the wobble and one to the top which made it way more solid. although from the sounds of it maybe somethings fucky since you said the looseness stops when you turn the bars. that sounds like ovalizaton
4/13/2014 10:51 PM
FEDEXdoobie wrote:
Try putting a slim spacer under and a thicker one on top of the stem to see if that helps. I had somewhat of a similar problem ...more
It is ovalized. Sent Joe an e-mail, hopefully I can get it sorted out. I got the stem as high as I could and it was still wobbling, even with it tightened to the point where it wouldn't spin freely.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
6/17/2014 3:52 PM
Been two months since I first e-mailed T1 and Joe's had my frame for about a month now. Still no word on what will be done about it. 10/10 would definitely recommend.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
6/17/2014 4:17 PM
Xxohioanxx wrote:
Been two months since I first e-mailed T1 and Joe's had my frame for about a month now. Still no word on what will be done ...more
The sarcasm is real with this one.
What the hell... It was better with Taj helping out.. Now its kinda sad to see how this is being handled.
