G Sport Ratchet Driver Question
2/16/2018 9:52 AM
My driver shifts partially in and out of the hub shell... I’ve never owned a ratchet or had many friends with one so I was curious how common this is. I remember the odyssey quartet cassette hub did the same with the press fit female axle.
The driver doesn’t skip or anything which is good but I was mainly curious how common this is and if it can be fixed with buying a new driver.
My Youtube / RainBMX
My Insta / What_Is_Barspin
2/16/2018 10:06 AM
Does it do it while you are pedaling? Or while the wheel Is off the bike? If it is the latter then it's fine.
Hmmm
2/16/2018 10:17 AM
I haven’t noticed any shifting when pedaling
I’m probably fine tbh. I’ll just wait till it starts skipping and/or breaks.
2/16/2018 11:42 AM
Edited Date/Time: 2/16/2018 11:42 AM
My Éclat Pulse did that , it has some play right ? And wobbles in and out slightly ?
It only happened when I got the bearings replaced . I’m not a hub guy so I can’t tell you what it might be , but I guessed maybe bearing fitment was off and that’s why it moved , or something with the pawls ?
2/16/2018 11:45 AM
It only happened when I got the ...more
Yeah it has side to side play but it’s working fine atm. So I’ll just start worrying till it begins skipping and whatnot
2/16/2018 11:58 AM
if its very slightly like 1-2mm its fine, my cheap ass rear wheel does it as well. but if its more than say 1/8 of a inch than you have to tighten the bearings with a cone wrench VERY SLIGHTLY than it should be fine.
2/16/2018 12:58 PM
When your wheel is tight, there should only be a tiny amount play. Any more would suggest something is worn. But the bushes butt up against the bearings, so the driver itself will float a little
2/16/2018 2:42 PM
I had the same problem with my Antigram hub which I assume is really similar. The ring that held the needle bearing in would slip out sometimes but after a year of riding it it never broke or had any serious problems..if it starts to make noise I would worry but if not then just ride it until it does
2/16/2018 3:17 PM
My Quartet hub does this and it drives me bonkers. I'm currently deciding on the bits and pieces for full customs, front and rear.
2/16/2018 6:53 PM
My antigram (the scaled down version of what you have) does the same. Contacted odyssey and they replaced my driver. Same thing happened within a few weeks of installimg and riding the new driver. I just accept it now, doesnt seem to cause any problems as of yet.
