G-Sport marmoset hub bearings
7/15/2018 7:12 PM
I have a g-sport marmoset front hub and i blew the bearings out. i need to know where to get new ones, and i need to know how to take it apart. many thanks to anyone that can help! Photo
7/15/2018 7:20 PM
Edited Date/Time: 7/15/2018 7:20 PM
Pull the collars off, put a bolt all the way into one side and tap it until the axle's out. There should be codes on the bearings, which you should be able to buy from a bearing shop.
7/15/2018 8:33 PM
p1p1092 wrote:
Pull the collars off, put a bolt all the way into one side and tap it until the axle's out. There should be codes on the ...more
The collars are stuck on. I tried tapping them off by putting a flathead through the spokes onto the back side, and it did not budge. both sides are stuck.
7/15/2018 8:47 PM
DanTheBikerMan wrote:
The collars are stuck on. I tried tapping them off by putting a flathead through the spokes onto the back side, and it did not ...more
Did you take the axle out? Lol.
WD-40 on the collar and let it sit, then take it apart...
7/16/2018 1:18 AM
My research shows two (2) 6804 bearings:
https://www.jrbicycles.com/g-sport-marmoset-front-hub
http://sdbmx.forumotion.com/t31-common-bearing-and-bolt-nut-sizes
Ebay has two (2) 6804-2RS bearings for $5.44 shipped here. (2 RS = Bearing with rubber seal on both sides)
7/16/2018 4:53 AM
Edited Date/Time: 7/16/2018 4:54 AM
Put a bolt about halfway into one side and tap the axle out: that'll remove one collar. To remove the other one and the bearing, put a bolt halfway into the other side, sit either side of the bearing down on some vise jaws or similar and tap the axle out. Then, use a punch or something to knock the bearing out of the hubshell.
7/16/2018 2:32 PM
Edited Date/Time: 7/16/2018 2:37 PM
p1p1092 wrote:
Put a bolt about halfway into one side and tap the axle out: that'll remove one collar. To remove the other one and the ...more
I had to beat the shit outta it with a mallet, the collars were stuck on so damn tight. it’s fully disassembled, and the collars refuse to slide back on so i’ll need some grease on em after i get the new bearings in. thank you for your help! Photo
7/16/2018 2:34 PM
...more
on the bearings it says “6804v NSK” and in smaller lettering “605”
7/16/2018 2:36 PM
...more
those bearings look like they should work perfect. thank you!
7/16/2018 2:38 PM
Advice to you and others, always grease the collars lol. I've always kept mine greased and they slide on and off like butter lol
7/16/2018 2:50 PM
I had to beat the shit outta it with a mallet, the collars were stuck on so damn tight. it’s fully disassembled, and the ...more
No bother man. If you break the inside corner of the collars(the ones that contact the axle first when you go to put them on) with a file and do the same for either side of the axle, it should make putting the collars back on a bit easier.
7/16/2018 7:18 PM
HondaCRFRacer wrote:
Advice to you and others, always grease the collars lol. I've always kept mine greased and they slide on and off like butter ...more
i got this hub used and i hadn’t taken it off my bike since i first installed it, much less taken it all apart. but i will definitely grease them.
7/16/2018 7:18 PM
p1p1092 wrote:
No bother man. If you break the inside corner of the collars(the ones that contact the axle first when you go to put them on) ...more
yup will do, i’ll post back after i get it all back together.
7/17/2018 2:25 AM
...more
V = Bearing with non-contact seals on one side
NSK = Manufacture
With the 2RS you're getting a much better seal at the slight cost of extra friction vs. the V.
