Gearing ratio help
6/2/2008 5:06 AM
I want to run a smaller sprocket cause right now I am running 39/14. How much smaller can I go without changing the freewheel, or is that going to be inevitable? Secondly, my crank arms are 175mm. I'm 6' 3 and I read some were that at my height I should run 180mm. What would the difference from a 170, 175, or 180 be? Some help here would be great. Thanks.
6/2/2008 5:11 AM
You can go down to 36 with a 14 tooth freewheel.
I awarded myself infinite cool points. Breaking the rules has never been this cool... EVER! Forever.
6/2/2008 5:16 AM
yea juss go down to 12 in the back and 32 or 33 in front thats wat i use to have u can see on my pictures and yea i would get som 180mm cranks u can probably find some profiles for cheap on ebay
6/2/2008 5:30 AM
My concern with running 180's is that I wear a size 15 shoe and I am afraid I may not have enough foot clearence from my rear peg.
6/2/2008 5:42 AM
If your bike feels good to you that's all that matters. I'm 6 foot and I'm still on a frame with a 20 inch top tube. People say I should get 20.5-20.7 but I'm more comfortable on a shorter frame.
6/2/2008 9:54 AM
if ur gonna buy a new freewheel and a new sprocket just buy a 22-8 or a 25-9 since u want a smaller one but if u use the same freewheel you can only use a 38 i think so just buy a new freewheel
6/2/2008 11:34 AM
i ride 36/13 seems pretty good
¡Odio patinadores!
6/2/2008 11:36 AM
get a 25/9
go ride a bike
6/2/2008 1:04 PM
Edited Date/Time: 6/2/2008 1:09 PM
do you have a flip flop hub that goes 14 on one side and 13 on the other, if so 36/13 will give you almost the same exact quickness but 33/13 will be real quick only you won't be able to go fast. You should probably just deal with what you got until you get money to get a new rear wheel. Any money you spend on just a sprocket could be used to get the new wheel man... I spent 50 bucks on a 36 when I still had my flip flop hub. Now I got a 50 dollar sprocket just sitting around and nobody wants it, but it makes a good back up when matched up with my old rear wheel in case of any problems with my new wheel you know, but I would rather have the 50 bucks back towards pedals and maybe even more!
