Ghosts playing pranks? Odyssey antigram problem
7/31/2017 9:29 AM
So just to start it off I have experience working on bikes but this has me stumped. I recently bought an odyssey anti gram rear hub. Literally it's been ridden 10 times at the most as I usually ride coaster. So just yesterday I went to my friends house and we rode for the day. At the end of the day we swapped cranks as my cranks were too short for my riding style. I took off the rear wheel and set it to the side as I was changing the cranks. My friend had to go so I left the rear wheel off and drove home. When I got home and went to put the wheel back on it acted just like a lhd hub put on a rhd bike. So you could pedal it backwards and you went backwards. Of course I've always ridden the hub rhd so I just assumed I threw the cranks on the wrong way in my rush to leave. Well they are actually on the right side so I put everything back together again. Now it does it half and half. It'll act like a lhd and then suddenly start working properly again for a few cranks and then switch back again. I'm completely stumped as to what happened as no one touched the rear wheel except to loosen the 2 bolts to take it off the bike. The only thing I can think of is a ghost changed the drive side or something haha. If anyone could shed some light on this it would be awesome. Thanks.
7/31/2017 10:08 AM
Maybe one of these cone nuts tightened while tightening the wheel down making the bearings really tight. Used to happen to me on my old hub.
I ride my tiny bicicleta to skooooooo
BOTTOM TEXT
7/31/2017 10:55 AM
Weird, your best bet is to find the ghost that pranked your bike and make him fix it.
7/31/2017 11:52 AM
This happened to my friend's bike once. It was the weirdest thing, haha! He re-greased the pawls and cleaned the internals and worked fine after that.
7/31/2017 12:31 PM
Pawls need to be greased as Ready said above me . It should work after that . If not , I do not know.
7/31/2017 5:11 PM
I wish I had an answer...this is nuts
8/1/2017 12:00 PM
GCBMX69 wrote:
Maybe one of these cone nuts tightened while tightening the wheel down making the bearings really tight. Used to happen to me ...more
It's a fully threadless press fit cones. There is no way to overtighten them. Thanks though.
8/1/2017 12:01 PM
readybmxer wrote:
This happened to my friend's bike once. It was the weirdest thing, haha! He re-greased the pawls and cleaned the internals and ...more
Ok I'll have to try this haha. It's just strange as the wheel is basically new and was greased once already.
8/1/2017 2:16 PM
Yeah chances are, as it's bushes as opposed to cones, the driver may have slipped free a touch and the springs and pawls moved. Just open it up, check everything is where it should be, add a thin layer of grease, and it should be fine
8/1/2017 3:05 PM
Edited Date/Time: 8/1/2017 3:08 PM
Maybe you put your pawls on backwards. It's switchable. Put them on the other side. Nevermind, I missed the last part of your post. Maybe someone is messing with you. God did it man.
8/2/2017 4:28 PM
Make sure you have the cone on right on the drive side
