Good Weight for a frame
2/3/2017 6:53 PM
What is a good weight for a frame alone, looking at some to build up my first bike, just curious what a good weight is for a frame. Thanks!
2/3/2017 7:05 PM
Edited Date/Time: 2/3/2017 7:06 PM
5lbs is about average, don't go too far under that and it should hold up.
2/3/2017 7:19 PM
This. 5-5.5 lbs is pretty common. Not easy to go above if you want a modern frame, and not as easy below 5 lbs either.
2/4/2017 7:07 AM
I'd like a frame to be around 4 lbs.
2/4/2017 9:03 AM
Edited Date/Time: 2/4/2017 10:27 AM
That 1 less pound is almost 1/4 less material. You can loose a pound of weight by just changing your tires. A four pound frame will never be as strong as a five pound frame. It's probably about 25 percent weaker. Just to save a pound. Don't look at it too hard, it might dent, but if your carefull, and don't drop off any curbs you'll be good. Lol
Seriously though I guess if you only ride trails, and don't use pegs 4 pounds might work. It's not gonna hold up to street abuse for very long though.
2/4/2017 9:10 AM
In between 4 &1/2 and 5 is usually what my frames weigh, my current one is 5lbs and it's perfect for me.
“Pegless and coaster is ultimate zen”
-Indiana Tom
2/4/2017 10:34 AM
ggallin422 wrote:
That 1 less pound is almost 1/4 less material. You can loose a pound of weight by just changing your tires. A four pound frame ...more
Yeah light tires are good too. I ride tioga powerblock folding tires, or maxxis foldings usually. I usually don't worry much about the strength of a frame.
2/4/2017 10:50 AM
Currently 5-5.5 is average . I think a couple years back 5 was on the heavier side , you can still find frames that are 4 pounds and even in the 3 pound category , although it'll be an aluminum can . As mentioned , you can easily save weight by getting light tires , or plastic parts .
2/6/2017 1:28 PM
To me if the bike is under 25 lbs i cant hop as high because it gets away from me.
2/6/2017 3:31 PM
I rode an Eastern Journey for a couple years without issue, on nothing but street and park, with and without pegs. Sold it to a buddy who still has it now.
2/6/2017 7:33 PM
As a rider who guerra gave their martyr for a steal of a deal and cracked the head tube I'd say 5 pounds is a good spot
