Grease?
2/2/2015 11:21 AM
What grease should I be using on my chain? I used WD-40 and it made it full of black gunk all over the chain and the driver. I cleaned it all out and I used Weldtite Cycle Oil on it and it had the same results.
I just got a can of Holts Spray Grease
Description :
Lubricates and Protects every part. Non drip - High cling. High temperature. High pressure. Anti rust. Drives out water. Powerful direct spray
Is it worth my time cleaning my chain and driver out and putting this stuff on or will I be wasting my time?
2/2/2015 11:47 AM
Greece is a beautiful country
13 years old
2/2/2015 11:56 AM
I use Epic Ride from White Lightning, its cheap, gets the job done, and I can pick it up at Walmart, hope this helps.
2/2/2015 12:04 PM
They're all the same to me
2/2/2015 12:08 PM
I'm in Ireland
2/2/2015 12:12 PM
kaneBMX wrote:
I'm in Ireland
I used park tools grease. on grease lightning!
"The D.O.P.S. System"
DK, Odyssey, Profile, Shadow.
check out my bike check
@ethanbrackett
2/2/2015 12:16 PM
A good chain lube, only use wd40 if your cleaning your chain.
2/2/2015 12:18 PM
I wouldn't use grease on a chain, as you said it will get gunked up.
2/2/2015 12:21 PM
I use the wax-type grease. It's awesome and also prevents against corrosion. I think they sell it on dans for like 5 dollars
2/2/2015 12:27 PM
>Dans for $5
>Shipping : 30 euro
>Import fee : 30 euro
2/2/2015 12:45 PM
kaneBMX wrote:
>Dans for $5
>Shipping : 30 euro
Then search for some and stop complaining. We've told you what you need, do some research. And you want wet luben
2/2/2015 1:39 PM
I'm asking if Holts is ok to use and no one is giving me a straight answer
2/2/2015 1:42 PM
look Kane, ANY grease will work. any poly based water-resistant grease will work JUST FINE ITS PIGS FAT FOR CHRIST SAKE
local hardware store, get a tub of it for like 3 or 5 quid, and maybe some rubber gloves, and your GOOD!
@ethanbrackett
2/2/2015 2:27 PM
Do NOT ever use WD40 for lubing your chain, cleaning is okay, but WD40 is not for lubing your chain adequately. You might as well be rubbing your ball sweat on your chain if you're doing that.
Also do NOT EVER grease your chain, use fine lubes. See if you can find 3 in 1 oil at a store near you, I use that as an alternative when I don't have White Lightning chain lube at the moment.
As for grease, you can use that grease for whatever else you want as long as it's not for your chain, such as greasing your bearings, bearing seats, driver, etc.
2/2/2015 2:39 PM
sundaybmxRR wrote:
Do NOT ever use WD40 for lubing your chain, cleaning is okay, but WD40 is not for lubing your chain adequately. You might as ...more
i use 3 and 1 on my chain while i catch access lube with a rag running it under the area i am lubbing it up
Testimony and apologies
instagram
old edit
2/2/2015 3:49 PM
3 and 1 oil .. been using it for 30+ years.. This work good too..Photo
F¬ Bom 5403692331
2/2/2015 4:30 PM
WD-40 is a lubricant, people have been using it for years on chains
2/2/2015 4:41 PM
Edited Date/Time: 2/2/2015 4:42 PM
Don't use wd40 for anything on your bike it's not a lubricant its a de greaser
And don't waste your money on grease/lube from some bike shop or dans comp
You can go to an automotive store and buy a giant can of the exact same grease/lube that will last you a lifetime for your bike for the same price for some tiny pack of grease/lube you'd buy at a bike shop
2/2/2015 4:46 PM
If WD40 is a lubricant, then go ahead and clean out all your bearings & driver and replace the grease with WD40 and see how well that turns out.
There are specific types of WD40 you can use as lubes, but the traditional kind most everyone is used to, is not practical for lubing stuff up, especially chains.
2/2/2015 4:48 PM
Says right on the can of wd40 removes moisture
Drying your chain up is not lubricating it
2/2/2015 5:12 PM
Edited Date/Time: 2/2/2015 5:16 PM
sundaybmxRR wrote:
If WD40 is a lubricant, then go ahead and clean out all your bearings & driver and replace the grease with WD40 and see ...more
WD-40 is not a grease, it's a lubricant
You lube/oil your chain and grease your bearings, hence why you wouldn't put WD in your bearings.
>fine on chains
>internet arguments
2/2/2015 5:19 PM
You lube/oil your chain and grease your bearings, hence why you wouldn't put WD in ...more
You still can put oils/lubes in your driver/bearings. Lots of people do it and finer lubes/oils work much better in drivers than a glob of grease. If WD40 WAS a lubricant, then by your logic it would work just the same in the driver as it would on a chain.
But not being a lubricant, it won't. Which was the point I was trying to make, I guess I could've worded my last post a little better.
2/2/2015 5:34 PM
Lol that my comment was so fucked that it got deleted.
2/2/2015 6:12 PM
WD-40 is not nearly as good a lube as anything else you could use, theres many many other lubes out there that are better, WD-40 as a lubricant is better suited to door hinges and the like.
Instagram
2/2/2015 6:21 PM
Weldtite Cycle Oil looks like its about the same as White lightning. So you prolly need to reclean everything with Wd-40 or some kind of de greaser since black gunk is still coming out..(I used wd-40,worked great with a wirebrush) . Ive read that 50/50 gas/diesel works the best and cheapest way to clean your chain but I had wd-40 and it worked fine. One bike I bought used was greased and it worked but like others say it was gunked up and it ruined a few pairs of jeans and i had a grease tattoo of a chain and sprocket for 3 weeks on leg. So clean the chain until no more black gunk it present with wd-40, then relube with your Cycle oil. Or buy a new chain.
2/3/2015 4:01 PM
Don't use WD-40 for anything on your bike!!!
They have chain specific oil that you can buy from you local bike shop or maybe even Wal-Mart.
I would soak your chain in Coca-Cola (yeah, seriously) to get that shit off and then lubricate it with some KY Jelly.
"Ride it like you stole it."
Refs: SuperstarDK, Gage191
2/4/2015 4:08 AM
At the end of the day you could use cooking oil, anything that will cling to and protect metal from corrosion will work
Engine oil, Gt85, chain wax, spray grease (e.g lithium grease), the list is massive but it's only a singles speed bmx chain. Bottom line is don't use Wd40 or any hydraulic oils.
I take my chain off and wash it in a bag of white spirit a few times, let it dry and result it occasionally, I've used loads of shit and my chain still looks brand new and ice never snapped one.
2/4/2015 11:32 AM
I use my gun oil lol, slip2000
My FBM bike check
